cannondale forks
[Closed] cannondale forks
please help Ihave an old cannondale which has a 1nch stem for the forks Ineed new forks but cant seem to be able to get hold of any can only get 1;1.8th
Posted : 21/06/2012 11:21 am
You can buy [url= http://www.sjscycles.co.uk/m:part-ahead-stem-shim-adapts-1-1-8-inch-286-mm-to-1-inch-254-mm-prod3618/ ]shims[/url] to solve this.
Posted : 21/06/2012 11:41 am
But that's not going to make 1 1/8th forks fit a 1" headset though.
does your Cannondale have the Fatty headtube? If so it should be possible to buy either a reducer to fit it and allow 1 1/8th forks to be fitted or if it's got one fittee already it may be possible to remove the old 1" headset and fit a 1 1/8th headset to fit the new forks.
edit: to correct my appalling punctuation ๐Ÿ˜ณ
Posted : 21/06/2012 11:48 am
greetings pinkster thanks so its an old m900 frame showing my age but i have had marrazi xc s on it for years 60 mm travel i m now a bit fat and want 10mm travel
Posted : 21/06/2012 12:15 pm
Ian - I had this problem when building up a Cannondale M400 frame I was given. I ended up finding some brand new 1" threaded forks at a bike recycling centre that employed troubled kids / teenagers. You will also need a compatible 1" stem with the same thread pitch which your LBS should be able to help with. Shop round & see what your local bike shops have left lying around I would suggest, or contact me if you have no luck & I can see if they have any where I got mine from, but it was a couple of years ago.
Posted : 21/06/2012 12:16 pm
cheers superdale my local shop asked me to part with a oner 1 k of my hard dosh do u think i can get 100mm travel on a threaded head ? cheers
Posted : 21/06/2012 12:19 pm
Oh of course - my bad, I saw the word 'stem' and overlooked the rest of the post...
Posted : 21/06/2012 12:25 pm
Presuming you meant "over 1K" please tell me you havent spent that much on an old cannondale frame with a 1" headtube ๐Ÿ˜ฏ
I'm a big Cannondale fan but that seems a bit OTT
Posted : 21/06/2012 12:30 pm
stems don't have "thread pitch".
OP I dunno if any suss forks are made in 1" anymore - if so they won't come threaded. Your frame is 20+ years old and even if there's much life left in it a fork that long will change the handling a lot.
SH is probably the way to go.
Posted : 21/06/2012 12:31 pm
Kierian no no my man he wanted 1 k for new bike with crap parts do u know if i can get some nice i inch forks with 100mm of travel ta
Posted : 21/06/2012 1:08 pm
cynic-al thanks you are right Ido love the cannondale though
Posted : 21/06/2012 1:11 pm
its an A head stem
Posted : 21/06/2012 1:12 pm
Ian - I cant think of any suspension forks available in 100mm that will come with a 1" steerer. You might try PaceCycles who still have 1" steerers available but unsure what forks they would fit. Also as Cynic says it will effect the handling badly. My rigid forks are 410mm long to give you some idea and look like this fitted with a threaded headset and a quill to threadless stem converter.
[url= http://www.pinkbike.com/photo/8299263/ ]Cannondale M400 Circa 1991/92[/url]
I love riding mine for road blasts and gentle Xc trails its just soo light and quick compared to the full sus. You take a bit of a battering on anything rocky but it certainly helps your technical skills & makes you appreciate just how far MTB development has come in the last twenty years.
Posted : 22/06/2012 10:50 am
