Can you put 1.5-2.2...
[Closed] Can you put 1.5-2.2 inners in a minion / high roller (both 2.35)?
[#4477774]
LBS ran out, so gambled.
Thanks
Posted : 20/10/2012 2:53 pm
yup sure can
Posted : 20/10/2012 2:54 pm
Just realised I did with a 2.4 hr and 2.5 minion this summer. I didn't die. 😳
Posted : 20/10/2012 2:58 pm
I use a 2.5 - 3" inner tube in a 4" tyre....
Posted : 20/10/2012 3:02 pm
Weight saving innit? Neve noticed any issues, not quite the ironclad insurance policy of a full on DH tube of course.
Posted : 20/10/2012 3:33 pm
I've got 2-2.2 tubes in my 2.35 Mininons and I'm still alive.
Posted : 20/10/2012 4:01 pm
Smaller width tubes will usually work in large width tyres. However in doing so the tubes are usually more stretched e.g. the rubber's thinner after it's been done. As a result of which they tend to be more prone to punctures. Though it's more than possible.
Posted : 20/10/2012 4:11 pm
It'll be fine, once you take into account the Maxxis Rubber Ruler Factor you discover that a 2.35 Minion is actually under 2.2 anyway so you've bought the correct tube!
(in general, I've often used undersized tubes and maybe they pinch easier, but not so much that I can be sure)
Posted : 20/10/2012 7:17 pm
+1 to northwind. older Maxxis come up small. 1.5-2.2 spesh tubes ive used fine in 2.35" maxxis folders
a 2.25" (new) maxxis however (as big as a 2.5" old maxxis) I haven't got to work welll with 1.5-2.2 tubes. They're just too stretched
Posted : 20/10/2012 8:57 pm
