Can you convert Max...
[Closed] Can you convert Maxle 20mm forks to maxle 15mm
[#5236493]
Does anyone know if there is a way to convert Rockshox Reba forks with a 20mm Maxle to fit a 15mm Maxle as this is what my wheels are setup for and they cant be changed to fit a 20mm maxle. Would have thought some simple fork inserts would do it?
Posted : 11/06/2013 11:51 am
no - would need new lowers
Posted : 11/06/2013 11:52 am
 core
I'd take it to a local engineering firm and see if they can machine an adapter, if you take a 15mm maxle and the forks I'd have thought they could do something.
Posted : 11/06/2013 12:15 pm
The forks are threaded at one end and larger than 20mm on the other, with no pinch bolts. Add to this the fact that a standard 15mm axle is shorter im not sure how simple it would be to design and make a set of inserts. Almost certainly cheaper to flog fork and buy another or buy a new set of lowers.
Posted : 11/06/2013 12:18 pm
15mm Maxles are way more annoying than different wheel-sizes imo 😡
 br
[i]Almost certainly cheaper to flog fork and buy another or buy a new set of lowers. [/i]
Eh, surely the cheapest option would be to get a new wheel, or tbh buy Hope and then you only need a couple of inserts.
Posted : 11/06/2013 12:27 pm
Cheapest - 2nd hand lowers from a trashed fork - downside may be shagged
Next Identical hub but in 20mm flavour therefore reuse all spokes etc.
Then New Proper lowers fitted with a service and try and flog yours on (see option "Cheapest" on used lowers)
Or Buy a nice nw wheel/rebuild properly onto a new hub, about the same as getting a new wheel
Posted : 11/06/2013 12:31 pm
Thanks everyone, thought as much!!
Posted : 11/06/2013 12:59 pm
Contact Monkeyboy205 in [url= http://singletrackworld.com/forum/topic/26-inch-reba-forks-and-xt-chainset ]THIS THREAD[/url], he might be able to sell you what you need or point you in the right direction.
Posted : 11/06/2013 7:50 pm
