Can I reuse a fitte...
Can I reuse a fitted press fit BB
[#12860663]
My BB is 2 rides old.  Yesterday it was sounding absolutely horrible.  I assume its either not gone in square or that when I cleaned the shell out I did a poor job.  If I try and knock it out and refit will I  likely just make everything worse?  I have no proper removal tool so was going to buy one if its likely to be reusable otherwise I'll use my home made removal tool and buy a new BB - its just after a total of 25miles it feels rather wasteful.
Posted : 19/06/2023 4:47 pm
 Haze
Tap it out then re-fit, nothing to lose by trying...except a little bit of time?
(assuming cranks all correctly torqued etc)
Posted : 19/06/2023 5:02 pm
I have knocked mine out and re-used it a few times without issue, just do it gently and try to keep as much impact on the outer race as possible.
Posted : 19/06/2023 5:16 pm
If it can be removed without damaging the bearings (avoid hitting the inner race) then no reason it can’t be re-used
Posted : 19/06/2023 5:20 pm
Got the correct spacers on the cranks?
How do the bearings feel with the cranks removed?
Posted : 19/06/2023 7:32 pm
