Can I adapt my 1997...
[Closed] Can I adapt my 1997 P7 to run discs?
I want to run discs on my 1997 Orange P7 - anyone suggest a bodge?
I really don't want to fork out £450 for a new frame...
Ta
Matt
Posted : 21/09/2009 10:59 am
I really think just a front disk and a V on the back is enough.
Posted : 21/09/2009 11:02 am
A2Z disk adaptor?
Posted : 21/09/2009 11:20 am
Argos cycles?
http://argoscycles.com/www/renovation-pricelist.htm
Posted : 21/09/2009 11:42 am
Crikey £50 to weld a disc mount on not including the mount!
where in the country are you ? I had a mount welded onto an aluminium frame a few years ago at Chris Marshall cycles in Keighley (yorkshire) for £45 including the mount from Hope this included heat treating too, it can't have gone up by much if you're near give him a call 01535691073.
Posted : 21/09/2009 12:33 pm
If you do get it done, also get a brace between the stays put in, a couple of mates had disc mounts fitted to early P7 frames not designed for them and eventually the seatstays folded.
Posted : 21/09/2009 5:55 pm
Anyone know of a frame builder in Sussex/South East that can weld a disc brake mount/brace on?
Posted : 28/09/2009 8:36 pm
I asked Orange about this and they said welding something onto the frame would weaken it as it has been heat treated or something. A2z adapters don't fit say woollyhat shop- the only other option was a woodman disco, which uses the existing brake post and dropout. very expensive. A nice set of v brakes do a pretty good job tho
Posted : 28/09/2009 9:37 pm
Other alternative is the old style Hope universal caliper that bolts into the dropout with a hollow bolt
It then runs a torque arm up to the brake boss. It only runs a 155mm disc but I used it on my X2 then P7. Works best with a Hope hub because it needs a modified axle.
Have it all sitting in the garage if you're interested.
Rob
Posted : 28/09/2009 9:57 pm
Thanks for the help but think I might use it as an excuse to buy a new P7...
Anyone got a 21" P7 for sale?!?
Posted : 29/09/2009 3:26 pm
There's a 20" one on classified at the moment I think.
Posted : 29/09/2009 4:36 pm
