Campagnolo Scirocco...
[Closed] Campagnolo Scirocco 35 CX - Wheel bearing Help
[#7036472]
Hi Folks,
I've got a rough front wheel bearing on the above, has anybody had any experience in obtaining, if so where from, and replacing the sealed cartridge bearings?
Cheers in advance,
Red
Posted : 02/05/2015 8:23 pm
What year wheel? The spare parts catalogue at the Campagnolo website is great for seeing how things go together. The page you want is [url= http://www.campagnolo.com/AU/en/Support/download?td=3 ]here[/url]. Choose your year of manufacture and find the wheel in the right part of the catalogue. A search on-line should reveal the bearing equivalent for the Campag part number (e.g. the ones in my Khamsin front are the same as the Hope Pro 2 front bearing).
Posted : 02/05/2015 8:39 pm
And the ones in our R7s are the same as Hope XC so they use standard bearing sizes.
Posted : 02/05/2015 8:55 pm
Hi,
Genius...thanks for that chap, I'll go look....they're about a year or two old....hopefully they'll be the same!
Red
Posted : 02/05/2015 9:08 pm
So....HB-SC113, i've got the Campy parts for a set....where might I find the Hope alternatives?
Cheers,
Red
Posted : 02/05/2015 9:21 pm
For alternate bearings you'll need the code from the race. Then nearest bearing factor can give you a choice of many brands. I use SKF equivalents as that's what my one keeps in stock. 61804 2RS are the Hope front sizes, which also fit my Khamsins.
Posted : 05/05/2015 8:03 am
