Calling Fox Float R...
[Closed] Calling Fox Float RP2 Owners
[#768890]
Is there a maximum pressure (and therefore rider weight) for an RP2 shock? I can't find the answer on the Fox website.
I've just finished building my new Dawg up from a frame and I'm trying to set up the shock and it doesn't seem to take any more than 10 bar of pressure. This is about 50% sag for me. Is the answer:
a) loose some (more) weight;
b) get it serviced;
c) dig out the 5th Element knocking around in the garage?
Posted : 08/08/2009 3:05 pm
I have always understood the max pressure for Fox shocks is 300 psi and you usually put in approximately 1 psi for every pound you weigh with all your riding gear on and then alter up or down to get the right sag
edit: just had a thought your shock pump could be goosed if you cant get more than 10 bar (140 psi) in your shock
Posted : 08/08/2009 3:09 pm
Try another pump?
Posted : 08/08/2009 4:41 pm
 IA
140psi is pretty low. As above, they do up to about 300psi. I run mine at about 200.
Posted : 08/08/2009 5:51 pm
