Calling diabetics F...
Calling diabetics Freestyle libre 2 Garmin head unit
Hi beagleboy
thanks still trying, you’ve given me a new lease of life.
on the fill your details bit. GCM Connect, did you put anything in the libralink token box. And the libralink patient ID box?
thanks Stoddy
Posted : 09/11/2023 2:48 pm
@Stoddys
No, I just put in the email address and password I used to activate my LibreLinkup account.
Posted : 09/11/2023 3:07 pm
Ok thanks. Time to get back to work will try again later
Posted : 09/11/2023 3:15 pm
@beaglboy
embarrassing moment. I was expecting to see a data field on the screen.
after a lot of googling you can get to widgets by swiping down then across, who knew! Also found out that’s where the weather forecast is. Every day is a school day
now have the widget showing my readings.
thanks.
Posted : 09/11/2023 5:46 pm
had to write!
just got in from a cold Friday afternoon ride and whilst I was putting on the widget on my farming I also down loaded the data version of same app. When you choose what you want to see on the screen choose connect IQ then douse the data app for your GCM. 5 minutes into the ride it came up with my level. Refresh is a bit slow between 2&6 mins but I’m not concerned with that, also has a direction arrow.
thanks all for your help, I’m finally there.
Posted : 10/11/2023 6:03 pm
Need to proof read. ! I was excited
you get the idea. Insert garmin and choose in the appropriate place
Posted : 10/11/2023 6:50 pm
Sorry to drag this up from the past, but has anyone been experiencing problems with getting readings on their Garmin watch recently?
It's been working perfectly for me for the last 10 months, up until yesterday afternoon. Now all I have displayed in my watch is
no LLU credentials removing PW!
I've checked all the settings, password are matching up and Linkup is providing the correct readings but for some reason the CGM Garmin app doesn't appear to be connecting. I'd not touched anything prior to this error appearing and it was working fine before about 5pm yesterday.
Very weird.
Posted : 21/09/2024 2:25 pm
All working on my Garmin head unit, but since installing it, the Garmin goes to sleep after about 10 seconds and turns the screen off. It is still running and recording but screen is turned off - to save battery power according the the message. Press a button and the screen turns on and I see everything, but a pain to have to hit a button to see it...need to find the option to turn screen off to on!
Posted : 21/09/2024 5:56 pm
What are you using? I'm on libre 3, an ypsomed pump running CamAPS FX...I've got xdrip installed on my phone and I think there were 3 settings I needed to set - none needed a username or password...
Posted : 21/09/2024 6:04 pm
I'm using Libre 2, no pump. I'm using  Libre Linkup in my android phone, connecting the CGM Connect widget. Linkup needs a password setting in it, as does the widget.
This seems to be the problem as somehow the passwords on Libre Link, Linkup and the widget had got out of sync yesterday while I was in the gym. After resetting the password for all 3 apps 11 times I've finally got them all talking to eachother at last and it's all now working again.
I hadn't realised just how much I relied on it being so easily available on my watch these days until it wasn't.
Thanks @DickBarton for coming back, though.
Posted : 21/09/2024 7:20 pm
Just moved to the Tandem T-slim and back to Dexcom (g6). The pump connects to sensor, but sensor can connect to phone, so I've got the Dexcom app running on my phone.
I'm running the Garmin Dexcom Data field on my Garmin. When adding it to my data screen, it prompted me to login to Dexcom (via my Connect app on my phone). Enter details and 2 mins later, I'm seeing my blood levels on my Garmin. Not needing to use the Follow option.
I think Beagleboy may have posted similar up the thread, but the T-slim seems to work easily with Dexcom and as the Dexcom sensor is connected to the pump and it seems to just be the Bluetooth connection of the transmitter for the phone app, it all works easily with the Garmin head unit as well.
Posted : 23/10/2024 12:12 pm
Page 2 / 2
