Calling all tool ex...
[Closed] Calling all tool experts - will anything off-the-shelf fit this top-cap?
[#2937845]
Top-cap from a pair of DT Swiss forks-
Ideally somesort of 6-lobe socket?
[url= http://www.singletrackworld.com/files/2010/03/IMG_0285-648x486.jp g" target="_blank">http://www.singletrackworld.com/files/2010/03/IMG_0285-648x486.jp g"/> [/img][/url]
Posted : 12/07/2011 3:39 pm
Certainly will
Posted : 12/07/2011 3:44 pm
Yes, I'd love to mash the top-cap to pieces!
Posted : 12/07/2011 4:07 pm
uplink has a good point - as long as you wrap some tape around the punch so it doesn't mark the anodising you'll be able to use it to turn the cap.
I assume it doesn't all come off when you turn the knurled bit at the top?
Posted : 12/07/2011 4:17 pm
I'm guessing that knurled bit is an Schrader air valve cap.
Posted : 12/07/2011 4:22 pm
A pin spanner or circlip pliers and screwdriver will get that off with no damage.
Posted : 12/07/2011 4:25 pm
I'd definitely use a smaller hammer and punch but if you're a bit cautious of that approach, you should be able to get it out with something like this
Posted : 12/07/2011 4:29 pm
The 'proper' DT tool is a 6-prong socket - but (typically) it's not available!
Posted : 12/07/2011 4:32 pm
Is there an echo in here uplink?
Posted : 12/07/2011 4:37 pm
I have some pin spanners like above Park Tool, can you measure the hole diameter
Posted : 12/07/2011 4:48 pm
Try an angle grinder key(the one used to remove the lock ring that holds the blade on)there are various sizes and one might fit
Posted : 12/07/2011 4:53 pm
Pin spanner or circlip pliers.
Posted : 12/07/2011 5:01 pm
Circlip or needlenose pliars. Needlenose would be better I think, provided they're the right size/shape.
Posted : 12/07/2011 7:25 pm
You could try a big ball of blue tack pushed down on to it and then twist.
Definitely won't mark it and as long as it's not too tight may well remove it.
It's a trick for removing screw on case backs for watches when you don't have the correct tool.
Worse case scenario is it won't undo.
Posted : 12/07/2011 8:17 pm
Not a chance.
Posted : 12/07/2011 8:21 pm
