Hi
I have been offered a dune but its missing the end cap from the rear skewer has any one got one?, looks to be missing a securing bolt too.
The hub is a Rear Hub, KT 12mm x 197mm 32H but I do not seem to be able to source one?
Suppose I could get one made but thought I would ask first as bike is not rideable with out one so worth less.
I lost my front axle off mine. Messaged calibre bikes and go outdoors, and asked on here
Ended up with two spare.
I'd ask go outdoors. They were really helpful when I asked.
I have all the bits that came off my cracked frame, but can't remember if I saved the axles or not. Let me check the shed in the morning, you can have both if I find them.
Hi,
Thank you, its just missing the rear axle and nut from the end, i am pretty sure there is a grub screw into the gear hanger bit but I am sure I can sort this.
If you have them that would be great, thank you.
Just to be clear, we're talking about the black bolt thing that the rear thru-axle screws into...? The circular black thing on the silver hanger in this photo...?
Totally forgot to check this morning as I ended up in a rush, so will look when I get home.
Yep thats it.
If you got the axle too that would be great.
Not sure if there is a grub screw into the silver bit.
But basically the bit i need is that black bit.
Will not buy the bike without one.
If you could let me know that would be great.
Dave
I read that the mech hanger assembly is the same as on one of the Scott fatbikes, could be worth trying that too for parts sourcing.
K1100t if you have a 15 x 150 front wheel I would be interested in that if your selling?
@donkeydave looks like you're in luck! If you want it, PM me your name and address and I'll get in the post. You'll have to sort out your own grub screw I'm afraid, as I don't have one...
@Lummox I have both wheels, setup ghetto tubeless with Jumbo Jims, that I was saving for when I get my next fatbike. Can't see that happening anytime soon, rather they went as a pair though.
PM sent thanks
@k110t
totally understand wanting to sell as a pair, unfortunately the rear would be surplus due to having a fatty trail I’m just adding forks to. Thanks though
Al
