Cable chopper
[Closed] Cable chopper
[#1631646]
Just replacing cable outers. is it impetitive that i use some cycle specific cutters? I have some very good quality side cutters that i can vouch for...
What is the craic with ferrules etc... just check for ovality before the final install?
Immediate advice would be good... got a 1 hour window for fettling.
Muchos.
Posted : 21/05/2010 8:18 pm
Side cutters are much like pliers in this instance, a bit of a bodge for the job.
Why not try using them on an old piece of outer, or just cut a little bit off the end to see how you get on. I suspect you may just mash it a bit.
Posted : 21/05/2010 8:27 pm
They are ulra sharpe with minimal use... as long as it is a clean cut that all that matters ain"t it?
Posted : 21/05/2010 8:29 pm
Why don't you just give it a go on the every end of the excess cable & see how you get on, then?
It's only the same principle as using secateurs instead of scissors to do garden pruning...
Posted : 21/05/2010 8:37 pm
i did mine today and used a hacksaw!
Posted : 21/05/2010 9:16 pm
I bought some cheap side cutters from screw fix for this very job, they perform better than the previous bike specific cutters i had which lasted 3 cuts for 3 times the price
Posted : 21/05/2010 9:22 pm
 Keef
angle grinder. job dun.
Posted : 21/05/2010 9:25 pm
Yeah... someone mentioned tin snips?
Posted : 21/05/2010 9:42 pm
Tried all the methods mentioned with no joy.
Investment needed i think, anyone reccomend some durable cutters?
Posted : 22/05/2010 10:38 am
park ones are ace, had them years, and they are still good, well worth the money if you plan on using them alot, or for a long time
Posted : 22/05/2010 10:41 am
Dremel with cutoff wheel in , perfect square cut go slow and gentle so as not to melt the plastic
Posted : 22/05/2010 10:48 am
Seriously, as mentioned go to screwfix, and buy the cheap dude cutters with black/ blue handles with orange bits. About a fiver and better than cycling specific ones. Use them to chop through 25mm copper cable... As do alot of other electricians I know.
Posted : 22/05/2010 12:33 pm
Thanks for that peoples... i'm on it!
Posted : 22/05/2010 1:02 pm
Yeah thats the ones lyons, think they were 6 quid or something cheap like that
Posted : 22/05/2010 3:20 pm
Srew fix is the one! Job done and very clean cuts, thanks for the buzz mate... sending you a digital beer!
Posted : 22/05/2010 3:54 pm
In desperation I used a chisel and a lump hammer whilst resting the cable on a vice it cut cleanly!
Posted : 22/05/2010 3:58 pm
 tron
Can someone who's got a set of the magical cutters pick them out on the screwfix site so the rest of us get the right ones?
Posted : 22/05/2010 3:59 pm
Cant find them myself on the site for some odd reason, already had a look for tomahawk
Posted : 22/05/2010 4:04 pm
Bear with me....
Posted : 22/05/2010 4:13 pm
Item number 27403 😀
Posted : 22/05/2010 4:15 pm
Doh!
Posted : 22/05/2010 4:16 pm
