Burly steel 700c ri...
[Closed] Burly steel 700c rigid .....surly my only option ?
[#8109761]
Got an early sutra kona project 2 sans rack mounts on the cargo eapc
The amount of deflection under braking worrys me.
Theres 60lb behind it atm plus rider. And the back ends rated for 200lb. Better beef up the fork for my teeths sake
I accept that it will be harsher than the project 2 but what options do I have .....I saw the surly karate monkey fork and that's about it for 29er disk friendly.guard mounts /drilled crown a must Bonus points for Rack mounts and double points for mid mounts
My ideal fork after looking about is the updated project 2 on the kona rove...alas i have not seen it separate.
Posted : 15/10/2016 4:51 pm
 Andy
Depends on the a-c length you need/can get away with?
Posted : 15/10/2016 5:07 pm
I would prefer a full on 29er(470mm rather than a 425mm)to lift front end as the xtracycle rear end has dropped the bb and steepened the head angle by lifting the rear axle upwards
The big dummy fork - the ogre and the krampus all look good but are all pre order only.
Was just wondering if anyone knew of similar that would a. Be In stock and b. A bit cheaper than 80quid
Posted : 15/10/2016 5:12 pm
 tomd
Would something like an On One fatty fork work? I chucked a steel one out recently unfortunately, there must be a few of them knocking about from when folk have changed to carbon or blutos. They're seriously sturdy.
Posted : 15/10/2016 5:18 pm
 PJay
It's not [url= http://sellwoodcycle.com/collections/forks/products/700c-kona-p2-fork-hybrid ]this one[/url] is it? Why not contact Kona and see if they'll sort you out with one if that's what you really want.
I have a krampus fork that hasn't had much use if you're interested? Was thinking of selling it anyway
Posted : 15/10/2016 5:22 pm
http://webshop.singularcycles.com/en/Products/Singular-Swift-fork-touring.html
Not in stock there, might be some in shops if you ask?
Posted : 15/10/2016 5:29 pm
 Andy
Look at Charlie the bike monger or Triton. Loads of offering from Surly or Salsa. What about the ECR fork?
Posted : 15/10/2016 5:30 pm
Triton mostly out of stock . Loads that fit the bill if I'm willing to wait a couple of months
Ecr forks did look good. Have dropped swanny a mail atm though
Posted : 15/10/2016 5:39 pm
wooo got some krampus forks (not swannys they were much too short of steerer)
hopefully now my front wheel will not feel like its about to snap off under hard braking 😀
Posted : 27/10/2016 7:17 pm
