Burgtec/Sram Eagle ...
[Closed] Burgtec/Sram Eagle Issue
[#11202406]
Since ive ran Sram Eagle ive never had this issue and im struggling to work out what the problem is. All of it is less than 500 miles old and before anyone says anything it isn't worn out. I swap components at an alarming rate so never wear anything out.
Running an X01 DUB Crank with a Burgtec 3mm Boost DM chainring. Running an XX1 Eagle Oil Slick chain. Im getting a horrendous vibration through the cranks when pedalling. Not just in the easy gears but whenever I put a bit of power down. It's the exact feeling you get when you put a new chain and cassette on and you don't replace the chainring.
Ive tried a brand new chain and its exactly the same, and I'm starting to think the chainring is at fault here.
Has anyone had any issues running Sram Eagle on a Burgtec chainring like this?
Thanks
Posted : 20/05/2020 8:26 pm
Probably is the chain ring I guess. The chain is aligned to the n/w teeth, yeah? Have to ask.
Also, you checked the jockey wheels just in case? Unlikely to be the issue but it is Eagle...
Posted : 20/05/2020 9:13 pm
The chain is definitely engaging properly on the jockey wheels?
I know an idiot who didn’t loop his chain through the little tab on the cage, took me him ages to work out what I’d he’d done wrong...
Posted : 20/05/2020 10:00 pm
