Building up a new S...
[Closed] Building up a new Stumpy- PF 30 and crank questions...
I was about to buy a Stumpy Expert Carbon but decided to get a (discounted) frame as I'm going to use my existing Pikes, wheels bar, stem and Reverb.
So the frame takes a PF30 BB, it actually comes with a SRAM plastic one in the box but I'm thinking of getting a decent Alu one, like Wheels Mfg or KCNC. CRC are doing oldish BB30 XO 10 speed doubles for £100 which I'll swap the spider for a DM ring.
http://www.chainreactioncycles.com/sram-x0-10-speed-chainset-bb30-bb/rp-prod81599
Those with PF30 experience, what's the best setup BB wise, I'm partial to SRAM cranks because of the removable spider.
This will go with 1x11 M8000 XT drivetrain.
Posted : 31/08/2016 6:55 pm
My enduro still has its three year old sram pf30 cups in it with one change of bearings. But it does not often get wet and never use the bike wash.
I glued them in and it's all nice and quite.
Posted : 31/08/2016 7:08 pm
3 YEARS OLD?!! wow! my one year old enduro is about to get it's fourth set of bearings. to be fair it gets very wet very often and i am not the best at keeping it clean.
I am currently using a wheels mfg BB, which is alright. bearings are easy enough to replace. it seems to me that BB bearings are a consumable item like cassettes and chains these days.
Posted : 31/08/2016 7:20 pm
SRAM X1 direct mount crank on my hard tail and the original SRAM PF30 BB lasted weeks. I don't rate the original plastic cups but to be fair the amount of water that ran out of the frame probably didn't help the bearings and no I don't power wash the bike. Replaced with a Hope PF46 which works by both cups screwing onto a centre tube so effectively locking itself into the shell. £85 so a bit pricey which is the only downside.
I converted from 2x10 and I think the weight savings was about 400g.
I'm also running XT M8000 at the back.
Posted : 31/08/2016 7:43 pm
Fitted a Hope PF46. The Sram one didn't make 12 months.
Posted : 31/08/2016 7:48 pm
Maybe I'll use the SRAM one and see how long it lasts before I upgrade. Decided to stick to my old (perfectly serviceable) 1x10 XT kit after pricing up M8000. Still going for the XO cranks though.
Posted : 31/08/2016 8:07 pm
Fit a Hope one. Might be a bit more expensive but worth it.
Posted : 31/08/2016 8:08 pm
With the hope pf46, once you've installed the cups, can you just replace the cartridge bearings when required? And is it a simple case of knocking them out and pressing some new ones in?
Posted : 31/08/2016 8:51 pm
Cool, will give that a go.
Posted : 31/08/2016 8:55 pm
For winter I use a rigid ss with bsa bb the enduro never sees the winter mud.
Gluing the cups in means it is just the bearings that I change not a whole pf30 bb
Posted : 31/08/2016 9:01 pm
Should build up into a nice bike. I have the xo xt 11 speed setup on my Enduro. Needed a spacer on the drive side as the chain ring was too near the chainstay. Went with the 170mm cranks for a bit more clearance and running a 28t ring. Will probably fit the bigger cassette when they come out and go back to a 30t one. Never used the SRAM 32t that came with it.
Posted : 31/08/2016 9:10 pm
