Broken Talas RL!!!
[Closed] Broken Talas RL!!!
[#1614959]
Bought a set of the above with a slight oil leak.
Replaced the seals and oil no problem.
Being the ham fisted half wit that I am I overtightened one of the bottom nuts and snapped it off!! I should have used a torque wrench I know but its too late now!
Its the left hand side as you look at the forks on the bike from the front.
Am I right in thinking this is the non Talas side and if so where can I get a replacement part?
Any help gratefully received.
Posted : 17/05/2010 9:02 am
http://www.tftunedshox.com/contact/contact.aspx
http://www.mojo.co.uk/
What ever you have done these guys will sort it out. It may be expensive though but if you brought them second hand you'll have saved some money.
Posted : 17/05/2010 9:08 am
If you give Mojo a call they should be able to advise you what part you need and supply it. They have always been good for advice when I've called. 01633615815.
Posted : 17/05/2010 9:09 am
Thanks Captain.
I do have a quote however I just want to confirm if if the parts are available to do it myself (poor record so far but I am actually resonably capable!) and if its the expensive side that I have broken. I dont think it is but I just want to be sure.
Posted : 17/05/2010 9:11 am
tf tuned can normally supply the parts if you phone them
Posted : 17/05/2010 9:14 am
Spoken to Mojo and the part is circa £70. The quote I have is probably reasonable given the labour involved so I think its just a case of an expensive lesson learned!!!
Many thanks for the advice all!
Posted : 17/05/2010 9:16 am
