Broken off thorn pu...
[Closed] Broken off thorn puncture - ditch the tyre?
[#2679436]
Partner picked up a thorn puncture on a recent night ride. Despite being really careful I managed to break the damn thing whilst trying to get it out - first time ever I've not been able to remove the whole thorn.
The remainder is buried in the carcass of the tyre - should we carry on using it, ditch it or attempt removal with a sharp blade?
Posted : 20/04/2011 3:22 pm
FFS. Knife tip. Wiggle.
I need to wipe my arse - which hand?
Posted : 20/04/2011 3:24 pm
Posted : 20/04/2011 3:29 pm
Well that's me told then 😀
Had to get the thorn out in the dark and not sure how much is left - will have a dig later.
Posted : 20/04/2011 3:30 pm
try using a paper clip.i once had a very small shard of glass that i couldn't see/feel,but it kept causing punctures when i re inflated the tyre.i had to use a desk light to try and spot it,then use said paper clip to push it out.it worked a treat 🙂
Posted : 20/04/2011 3:32 pm
Use a screwdriver and just push it all the way in or out.
Posted : 20/04/2011 4:06 pm
I had that once! Damn thing was ****ing invisible. Took me ages to figure it out. On a p*ssing-wet day, of course.
Posted : 20/04/2011 4:18 pm
run it tubeless with sealant.
Posted : 20/04/2011 4:34 pm
Call 999 immediately
Posted : 20/04/2011 4:45 pm
 muff
don't know if i'm stating the obvious here or not. But just jam something hard (like a screwdriver) into the area from the inside, the whole will flair out and you can just pick it out.
Posted : 20/04/2011 4:51 pm
Hmmn, can't find the bloody thing now.
I've tried Hdruid's tissue test but no luck.
Ms Spanner refuses to line up valves with logos, because ' I'll look like a STW saddo' so no frame of reference and I didn't mark the tyre.
Guess we'll just have to wait for the next flat and go from there.
Tubeless? It took me 15 years to accept disc brakes - I'm saving tubeless for retirement.
Posted : 20/04/2011 4:52 pm
 muff
ducktape the inside of your tire. out of sight out of mind.
Posted : 20/04/2011 4:57 pm
Tubeless or a drawing pin works for me
Posted : 20/04/2011 5:31 pm
They come out, I'm now running at a nice round 20 punctures this month. 18 on the crosser and 2 on the road bike. 17 of the crossers ones were thorns.
Posted : 20/04/2011 5:34 pm
20 punctures?! Get some slime tubes or slosh some Stans into your inner tubes!
Posted : 20/04/2011 5:41 pm
(anotherdeadhero) 😆
Posted : 20/04/2011 7:45 pm
