Breaks not working
[Closed] Breaks not working
I've got a pair of avid elixir 7 trail 180mm rotor and when I'm riding around the street the breaks work fine I can put the breaks on and try push the wheel and it doesn't move. But when I'm riding trails the breaks don't seam to work properly and I put on the breaks and try move the wheel myself and I can. This is really annoying how do I fix this?
Posted : 26/01/2016 6:32 am
Bleed them?
Or the usual advice for older Avids, throw them away and buy something decent.
Posted : 26/01/2016 6:33 am
When on a break, you aren't meant work.
Unless you meant brakes that is...
Posted : 26/01/2016 7:45 am
Disappointed it doesn't say "breasts not working" bloody STW clickbaait titles
Posted : 26/01/2016 7:50 am
Try to avoid errors in your own writing when correcting someone else!
coolhandluke - Member
Posted : 26/01/2016 8:08 am
Possibly you have contaminated pads. Could try changing them after cleaning the discs well with alcohol (Isopropyl, not Pinot Grigio)
Then go easy on the sprays/lubes...
Posted : 26/01/2016 8:49 am
Could be loads of things. Start with the simple stuff
Properly fitted and adjusted?
Lever adjusters need adjusting?
Pads worn out?
Pads/discs contaminated?
Need bleeding?
That said, Avids aren't the most reliable brakes out there, a full Avid service is generally "replace with Shimano"....
Posted : 26/01/2016 8:54 am
