Brand-x dropper and...
Brand-x dropper and GRX lever
 pnik
[#13205497]
Anyone done it and if so how? Both want the nipple end of the cable. Also would make it tricky to add tension without an inline adjuster.
I’ve looked at 5mm knarps (new word for me) but they all look too big for the gap in the lever. It’s external routing btw.
Posted : 29/03/2024 11:18 pm
 a11y
I’ve done it. Brand X post - internal routed - and GRX LH lever. Cable nipple installed at the lever end. Using a ‘knarp’ (although not heard then called that before) at the activator end at base of post. Had to get the cable tension spot on as I’ve not get anything in-line to adjust, but not too much of a faff.
https://www.ebay.co.uk/itm/112263408828
Posted : 29/03/2024 11:54 pm
 pnik
Thanks, although I think the internal one has more leeway as the cable end drops into a barrel so you can swap it for a knarp thing. The external one the cable drops straight into a recess about 5mm x 6mm max.  I’ll order one and see but I think they’ll be too big.
Posted : 30/03/2024 12:17 am
 pnik
Don’t know if this helps for scale.6F193F6A-FA0B-465A-BA16-4A3644EDC992
Posted : 30/03/2024 12:28 am
This works perfectly with the brand X ascend at post end
https://www.biketart.com/products/x-fusion-manic-cable-locking-barrel?variant=41519344484531
Posted : 30/03/2024 3:41 pm
Yep, those locking cable barrels are what you need. I ordered these ones below.
https://amzn.eu/d/c3e2qKw
Posted : 30/03/2024 4:06 pm
Solderless nipples is the generic term I think?
Standard (BMX brand) marketed them as Knarps in the 90s for shortening Odyssey’s overly long upper Gyro cables.
Does the post not come with one? Plenty dropper levers need the nipple at the lever end.
In-line adjuster definitely beneficial.
Posted : 30/03/2024 4:51 pm
 pnik
Thanks, I had a revelation today that I have a part that will fit if I rotate it 90 degrees. For unknown reasons I didn’t consider that! Thanks everyone, now I need an inline adjuster.
Posted : 30/03/2024 6:37 pm
a11y and a11y reacted
What will/did you use?
I'm in exactly the same situation. I've got an inline adjuster, but when looking for solderless nipples I also thought they all look too big. Was thinking some sort of crimp might work at the (external) seatpost end.
Posted : 30/03/2024 11:14 pm
 pnik
I have a 5mm cable clamp from an old ks lev post that just fits end first. I’ll grab a picture later, don’t know the part number but it is especially compact one.
Posted : 31/03/2024 8:50 pm
 pnik
IMG_0106IMG_0105
Posted : 01/04/2024 12:56 pm
Brilliant, thanks 👍
Posted : 01/04/2024 2:07 pm
