Brand-X Ascend II a...
[Closed] Brand-X Ascend II air pressure adjustment
I’ve seen reference to adjusting this but can find no illustrations or instructions on how to do so.
Namely the external mounted versions (27.2 in my case), is there a valve under the hex bolt located under the seat clamp? Or is this bolt to be avoided at all costs?
Posted : 12/07/2019 11:23 am
There is no valve on the external posts, it’s a sealed cartridge inside.
Any with pressure adjustment have the valve where the bolt you are seeing is and it’s covered by a rubber cap.
Posted : 12/07/2019 11:31 am
What would happen if I undid that bolt, is it holding anything together?
Posted : 12/07/2019 10:19 pm
The bolt is holding the top of the cartridge. Nothing will happen if you undo it.
Posted : 13/07/2019 10:07 am
