brakes can I swop l...
[Closed] brakes can I swop left to right on the handle bars
 les1
[#6001464]
I've got a set of brakes of eBay can I swop them to opist sides so that the front brake will be on the right side of handle bars , they end up ,up side down will they get air in them or am I beening silly ! They should be air tight any way ? Pls advise will it be OK to do this
Posted : 01/03/2014 10:16 pm
Maybe you should just fit the bars backwards.
That way you'd not even have to swop the levers from left to right.
Posted : 01/03/2014 10:19 pm
Just swap the hoses over.
Posted : 01/03/2014 10:20 pm
What brakes are they? Avids are swappable, not sure what other brands are though?
Posted : 01/03/2014 10:30 pm
all depends on the brake, new Hope - fine, avid - fine and a few others.
Most brands are flip flop design, ie the same top & bottom so you can flip to either side, shimano are not, lots of OEM brakes come euro. Sod's law I ride euro & recently brought some depression for my play bike and the were uk, I need to swap mine!! Doh!!
Posted : 01/03/2014 10:35 pm
Just did a hose swap on some SLXs, apparently they don't need bleeding if you do it quick / right. Good luck with that...
Posted : 01/03/2014 10:42 pm
shimano are easy to swap without bleeding as are tektro if in doubt Epic bleed solutions have a how to shorten shimano hoses without bleeding [url= http://www.epicbleedsolutions.com/blog/shorten-shimano-hoses-without-bleeding/ ]here[/url] just leave out the shortening bit!
Posted : 01/03/2014 10:48 pm
You seem like a smart guy give it a shot.
Posted : 02/03/2014 12:41 pm
Why would anyone want to?
Serious question
Posted : 02/03/2014 1:10 pm
TheArtistFormerlyKnownAsSTR - Member
Serious question
Because they've bought a set of brakes set up as front/ left and want front/right I suppose?
Posted : 02/03/2014 1:16 pm
Yep, it all depends what kind of brakes you have. What kind of brakes do you have?
Posted : 02/03/2014 1:42 pm
 les1
Thank you for the response ,they are shimano deffo not the same to look at made to be one way up ,black cover on one side will see how they go ,then swop over the hose quickly see what happens
Posted : 02/03/2014 8:24 pm
New hope i.e. Tech 3s not fine. You could with the tech 2s
Posted : 02/03/2014 9:08 pm
