Brake mounting ques...
[Closed] Brake mounting questions.
I have Rockshox Revelation fork which is Post mount. I was going to fit Hayes 180mm brakes so bought a Shimano 180mm Post mount adapter. However with these things i bought an Avid brakeset instead , will the Shimano 180mm Post mount adapter be ok to use with the Avid caliper or will i have trouble due to Avid rotor being 185mm?.
The rear brake has an adapter but i have a Shimano one also same as front, again 180mm would this also cause problems with the new Avid brakes?
Help appreciated.
Posted : 21/07/2011 10:25 am
you prefer one type of brake mount adaptor to another? mmmkay...I tend to fit whatver I need to and leave it that. Good Luck...
Posted : 21/07/2011 10:28 am
LOL....reading back it did sound daft, didn't come out as i meant it to.
Don't want to buy another adapter if i don't need to.
Edit tool used ๐Ÿ˜†
Posted : 21/07/2011 10:36 am
The brakes will work better if you use the correct size adaptors ๐Ÿ˜‰
IIRC if you are using 180 mm rotors, Shimano adaptors catch the tabs on Avid pads but you can always cut them off.
Posted : 21/07/2011 11:26 am
Played it safe and bought proper Avid adapter.
Posted : 21/07/2011 5:42 pm
