Brake mounting plat...
[Closed] Brake mounting plate.
[#377787]
Hi All,
I am looking at fitting a 205mm disc to the front my 05 RM ETSX. At the mo its got a 185 front rotor and a 160 rear on the bike.
So my thinking is that if I put a 205 on the front and fit the 185 to the rear it will give me better braking!!!.
Now the thing is, what type of mount do I need?
The brakes are Avid juicy 7s with caliper mountings at 74mm centres. Front forks are RS revs, 08's. Not measured rear sizes yet.
Cheers, STEVE.
Posted : 10/03/2009 4:00 pm
is (fork)to post (brake) front 205
is (frame)to post (brake)185 rear
the 185 front will be a 165 if you put it on the back sadly.
Posted : 10/03/2009 4:16 pm
Thank you.
Posted : 10/03/2009 4:34 pm
