Hi all, I have just got a new set of deore brakes and the rotors on my CoTic soul seem to big for them. What do I need to make them work ?
The spacers off my old formula brakes don't seem to line up with the rotors. It rubs on the front and doesn't work on the back.
What size are the rotors ? And what forks do you have ?
Rock shock revs,
203 front
180 back
Have you got the correct Shimano brake adaptors ?
No I don't. I just found them online then. Might be a silly question but will shimano adaptors line up better than my old formula ones ? Cheers
Yes
If you have Deore brakes and your Revs are post mount you need
[url= http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747 ]The 203 option here[/url]
For the rear
[url= http://www.chainreactioncycles.com/shimano-mount-adaptor-rear-post-to-is/rp-prod13749?gs=1&gclid=CI_mvOm-o8QCFc7LtAodVR4ALg&gclsrc=aw.ds ]The 180 option here[/url]
But you may find the 180 rear rotor catches it did on my Soul due to being close and the flex in the frame. Think they are better / its advised with 160 rear.
Thanks for your help shredder
No problem.
