Brake disc compatab...
[Closed] Brake disc compatability Q?
[#3820334]
Hey guys, I'm running BB7's with SLX discs at the mo and they work well, but I'm looking at having a shuffle between bikes and was wondering does any one run SLX brakes with avid discs?
The discs are fairly new and the brakes will be brand new, but I don't know if the shimano pads require fancy discs?
I wasn't too worried about experimenting with the BB7's because it's a commuter but the SLX brakes will be on the full susser.
Any advice is appreciated.
Posted : 29/03/2012 2:56 pm
As long as the overall diameter of the disc is the same as what its replacing you should be fine. Some discs are slightly wider, but that shouldnt normally cause a problem.
Posted : 29/03/2012 3:12 pm
I use XTR brakes with Avid rotors, it's fine, as above; a rotor is a rotor, as long as diameter matches.
Posted : 29/03/2012 3:33 pm
Cool, I couldn't see any obvious problems, but it was nice to be reassured.
Thanks, I'll get spannering!
Posted : 29/03/2012 3:49 pm
