Hi
I have a 2013 trek x caliber 29er
I want to change the brakes but am not sure what would be a straight swap or if I wanted to fit say hope what I need to buy to fit them (ie mounts)
Current brakes are
Brakeset
Avid Elixir 1 hydraulic disc brakes
Any words of wisdom appreciated ...
Get some Shimanos
+1 for Shimano, heart wanted hopes but head bought XT's and they are fantastic.
+1 for shimano...go for SLX cheaper and pretty much the same as XT
You may need to change the mounts Somtimes mix and match between brands works fine
But they do not add much to the cost of a brake upgrade to get the matching ones
What size rotors have you got
And for me hope evey time because I hate not being able to get spare parts for stuff
What's wrong with what you have? How would you like the new ones to feel?
The only trouble with the Hope ones would be stopping.
Personally I'd go further up the Elixir range to 9's or X's
But Shimanos are idiot proof and good at stopping you too.
(Neither should require different mounts assuming you keep the same size rotors)
Hi
Thanks for the reply .
I am used to running better brakes these ones are not great.
I did buy some used ones from eBay but bike shop said they cannot be fitted as we're incompatible.
Too old apparently
I bought an m4 and a mono min no3 I think..
My bike I believe has post mount with a 20 spacer.
Rotors are a 160 and 180
Don't want to buy the wrong ones again.
Bike shop told me any modern ones would fit..
Not sure if 29er size makes a difference too ?
we're incompatible.
Too old apparently
my bike has the older style fittings are they for sale?
No difference at all. The only thing that is incompatible is the disc size if you have post mounts. Even then there are some +0 adapter out there just not normal kit.
Hopes are nice and despite what the shimano camp say plenty of power with good control. They will also last ages.
May be worth changing the discs anyway as some have less braking surface then others which makes a difference.
Hope, Shimano and Formula won't do you wrong. You might like Magura but they're a bit [i]weird[/i]. Avid might be alright or they might be an endless pain in the arris.
But the trouble with brakes is, it's not all about power or quality, it's about feel and no one brake suits everyone- if anyone tells you one brake is best, it's useful as you now know their advice is all cobblers 😉 See if you can try some, lever feel is as varied as it is important.
They said the no3 cannot be fitted as there wasn't a disc to go with it available
Yes both brakes are for sale.
I just want to know what I can fit instead without buying new mounts
You used to be able to get "post to is" mount adaptors but not tried for a for a while
Most of these would need to go up a disc size
So 200 mm disc rather than the 180 disc the no.3 is Ment for
Seem to remember Somtimes it jut would not work
Looks like hope still make there one
https://www.google.co.uk/shopping/product/1078374291549430650?q=post%20to%20is%20mount%20adapter&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari&sa=X&ei=wyAKUbyRLIXL0AXph4HwDw&ved=0CDoQ8wIwAw#hsec:overview
Opps
That mount I linked to is the fit the mono mini to the fork
I'm guessing you would want the m4 on the front and mini on the rear
Billyblackheart - if you have any Hopes that don't stop you then I'll dispose of them for you. They stop me fine. Avids? Less so. But that's just me.
As an observation I've made before, Hopes seem to get a better reputation amongst heavier riders, rides that like modulation and riders that don't think 200 discs work better for XC (they don't - brakes need to be worked reasonably hard to be at their best).
Light rides, who like an on-off feel, and run 200 front and rear on canal towpaths should look elsewhere.
