Guys,
I have bought a Pair of Marzocchi AM 2 shocks with post mounting for the brake caliper, these have not arrived yet.
I currently have Magura ronin 110's with IS mount and a Hope mono M4 IS mount caliper with a hope adaptor to allow the use of a 203 rotor.
I want to swap my forks for the marxocchi ones and retain the 203mm rotor.
So my set up will be
Post mount fork
and Hope IS caliper
203mm rotor
Is this the adaptor that I need.....
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13735 ]Clicky Linky[/url]
It says in the description that it does not fit Marzocchi forks .... aaarh!
Is there an adapter out there for me??
Does the M4 already use a '+20mm' adapter to work with the rotor? If so I think you'll be ok.
Is there a code on the M4 caliper?
I 'think' I bought a IS-IS +20mm adapter to fit it to the 203mm rotor.
I am not near the bike at the moment, what kind of 'code' am I looking for on the caliper?
Thanks for the help so far.
