Bottom bracket quer...
Bottom bracket query
I've got a Voodoo Bizango. I just got a good deal on an SLX M7000 crankset so I now need to switch to a Hollowtech 2 BB instead of the original Powerspline.
The Bizango has a 73mm threaded BB shell so I think that means I can use any threaded Shimano BB designed for MTB, such as SM-BB52, BB-MT800, SM-BB80. Is that correct?
And then I just have to get the correct tool because Shimano changed the indent pattern in the BBs at some point?
Assuming the above is correct I'll probably just get the SM-BB52, is there any reason not to?
Thanks in advance for your help!
Posted : 16/09/2022 10:08 pm
Yeah, just use the supplied spacers (or don't) to get the right chainline.
Posted : 16/09/2022 10:19 pm
Pretty sure the BB52 has the old spline pattern.
But you can get tools pretty cheap that fit both types of Shimano BB - https://www.ebay.co.uk/itm/325003596391
and the 73mm BB shell just needs the 1 spacer on the drive side
Posted : 16/09/2022 10:57 pm
Fantastic, thank you both.
I get that I need one spacer on the drive side, but for future reference how would I look up how many spacers I need and where to put them?
Posted : 16/09/2022 11:17 pm
In theory, for 73 you need one spacer on the drive side, for 68 you need 2 on the driveside and 1 on the non drive side. In practice, these days that's usually true but sometimes you'll want to finagle it a bit.
Re the tools, if you need the new shimano tool it does sometimes come with the BB so I'd hold off
Posted : 17/09/2022 12:33 am
You could search on 'shimano hollowtech II spacer placement' and an image will give you the info or go to the Shimano website and pick your bottom bracket.
Posted : 17/09/2022 8:06 am
Thank you both, the spacer question turned out to be a bit simpler than I was expecting, for some reason I thought there were more variables than just the width!
Posted : 17/09/2022 9:27 pm
