Bottle cage with bu...
Bottle cage with built in mounting adjustment?
[#12875730]
Loads of adaptor plates around to adjust your bottle location but had anyone seen a bottle cage that has adjustment or a fixed offset built in?
Posted : 01/07/2023 9:48 pm
Yes, I did, and cant think where I saw it, naybe a recent FGF?
Posted : 01/07/2023 9:52 pm
Might have been the Bontrager BAT cage, has lots of holes/slots
Posted : 01/07/2023 9:58 pm
spooky_b329 reacted
Wolf Tooth Morse
Posted : 01/07/2023 10:02 pm
spooky_b329 reacted
Wasn't expecting any to pop up so a budget and a bling one is nice!  Not able to quite match the adjustment range of an adaptor plate though.
Thanks
Posted : 01/07/2023 10:27 pm
Wow, this is black magic shizzle.
Posted : 01/07/2023 10:30 pm
Any of these but side loading? I use a bracket thing but its still not ideal.
Posted : 02/07/2023 12:25 am
kelvin reacted
Fidlock magnetic "cages" have a small amount of adjustment in the hole slots but you can also flip them upside down which gives a fair amounbt of movement (although you need the bottles with the strap around to flip those too).
Posted : 02/07/2023 8:36 am
spooky_b329 reacted
The decathlon side load cage has an adjustable plate that clicks in
Posted : 02/07/2023 8:41 am
@frogstomp
You don't need the strapped on mounts, the mount on the bottle switches round also with a screwdriver - I've done it for aeris
Posted : 02/07/2023 8:43 am
I've been browsing without searching specifically for adjustable position, this one is dual position but doesn't state the adjustment range, doesn't look significant though.
Syncros Alloy Comp 3.0
Posted : 02/07/2023 8:51 am
The bottle bosses on my Banshee Rune are stupidly high up the downtube, so I use a Topeak alt cage mount & a Wolftooth morse cage to fit a full size bottle on it.
Posted : 02/07/2023 12:42 pm
  1. You're better off with a plate for more range of adjustment, plenty Topeak copies on eBay some with slots to offer plenty of range and pinpoint location, add a bottle cage with slots and you've got a huge range of movement.
Posted : 03/07/2023 4:48 pm
