Bos Deville High Sp...
[Closed] Bos Deville High Speed Compression
Hi,
I have 2014 Bos Devilles, the HS compression adjuster is on the bottom of the fork. When I bought them at the time, the shop told me that the instructions in the manual were incorrect (due a bad translation) and to adjust the HS compression you had to do the opposite of what it said in the manual.
I'm now thoroughly confused about which way adds HSC. If I flip the bike upside down, so I'm looking at the adjuster, can someone please tell me - which way do I turn it to add HSC?
Posted : 19/07/2015 9:30 am
Turn it tighter (clockwise) to harden it - according to the French language manual
Posted : 19/07/2015 9:37 am
Best way to understand what the knobs do....
Step away from the Internet.
Turn it all the way to a stop (count the turns/clicks) bounce the fork, now try the other extreme. Remember the difference in feel. Stick it back in the middle go for a decent ride and tweak as you go.
Posted : 19/07/2015 9:38 am
Eddie - thank you - presumably is that when the fork is upside down?
Mike - I would agree for LSC and rebound - but personally find it quite hard to tell on HSC doing a car park bounce test.
Posted : 19/07/2015 9:48 am
It's all in the pump ๐Ÿ˜‰ got to get the stroke count up
Posted : 19/07/2015 9:53 am
Clockwise adds damping. Look at the sticker on the bottom of the fork by the dials - that is definitely correct! ๐Ÿ˜€
Posted : 19/07/2015 10:00 am
But is that clockwise when the bike is upside down?
What is quite strange with the hsc is if you turn it clockwise it actually winds the adjuster out
Posted : 19/07/2015 12:17 pm
