Boost Chainline
[Closed] Boost Chainline
If the ideal boost chainline is 51mm why is my SLX M7000 53.4mm ?
Posted : 17/05/2018 9:01 pm
no idea
I guess you could move a spacer over from driveside to non-driveside.  I doubt anyone's pelvis/lower back would take offense at that
Posted : 17/05/2018 9:17 pm
Because the standard SLX chainline is 50.4 and boost is 3mm wider. Why its 50.4 you'd have to ask Shimano... I did know why once, probably something to do with 2x chainlines or the like.
Posted : 17/05/2018 10:22 pm
It's to because the chain would catch on the biggest ring at the back. Wolf tooth's website has a longer explanation.
Posted : 17/05/2018 11:33 pm
All brand’s chainlines are wider than optimal in order to give the clearances required between what is sometimes a bunfight over space between large volume tyres, chainstay/tyre clearance and chainring/chainstay clearance. Nothing to do with 2x.
The benefit of a bolt on ring is that you can alter the chainline with chainring spacers.
Posted : 18/05/2018 8:36 am
This. Every boost chain line I push inwards runs better, but as has been said, it's a bun fight for clearance between the stay, chainring and space for fat tyres.
Posted : 18/05/2018 9:09 am
