Boost Adapters?
[Closed] Boost Adapters?
[#7685945]
Hi chaps,
Does anyone know if Hope do Boost Adapters for their pro4 hubs?
Just bought a Santa Cruz, which didn't spec the fork as Boost, so built up a standard non-boost pro4 hub onto some nice rims. And got the bike today.... With a Boost fork!
I've dropped hope a mail, and will give them a bell, but just seeing if anyone knows on here to out my mind at rest, or whether I'm buying another hub!
Ricks
Posted : 03/03/2016 7:54 pm
Yes they do but you'll need to redish the wheel across slightly as it's annoying with it off centre.
Posted : 03/03/2016 7:59 pm
Awesome. Also just checked and got the part number.
HUB1009-14N
Any idea which side it'll need dishing more to? I've got good length spokes on one side and shorter spokes on the other as the erd was a good 2.5mm out!
Posted : 03/03/2016 8:05 pm
It sits closer to the disc side fork leg if that makes sense as the disc side spacer is the same as a standard one with a longer end cap on the non disc side
Posted : 03/03/2016 8:10 pm
Awesome. My longer spokes are the drive side, so will easily stretch across.
Damn Santa Cruz for updating their specs randomly.
Posted : 03/03/2016 8:20 pm
Which is the drive side on a front wheel ?
Don't you need to space the brake out as well ?
Posted : 03/03/2016 9:06 pm
The disk side.
No caliper/rotor spacing required if it involves re-dishing the wheel.
Posted : 03/03/2016 9:12 pm
Drive side is the non-disc side isn't it? Drive side is right, if you're sat on the bike.
Posted : 03/03/2016 9:39 pm
LOL - I read the question as "what is the non-drive side" 😳 rickon is, of course, correct (unless it's a Cotic Roadrat......)
Posted : 03/03/2016 9:44 pm
