Bolt up front hubs
[Closed] Bolt up front hubs
Does anyone make a front hub that has a bolt up axle and 6-bolt disc ready?
Would prefer cartridge bearings but not a deal breaker if it's 'cones and balls'.
Posted : 03/06/2012 12:18 pm
Surly do
Posted : 03/06/2012 12:26 pm
Thanks, I'll check them out.
Posted : 03/06/2012 12:31 pm
Hope and Superstar both do adaptors for their fronts... What are you after here? You can get bolt-in "QRs" for any QR hub too but they don't do anything different to a QR really, apart from being lighter and fractionally harder to nick.
Posted : 03/06/2012 12:42 pm
I've not seen the adaptors from either Hope or Superstar. If they exist then a bolt up Pro II would fit well with the rest of my wheels.
I'm after a front hub that you bolt in place rather than anyform of quick release. At a push I would use a 'security' skewer in a quick release hub but I'd rather start off with a bolt up hub.
The Surly hub looks ideal but is £60+ which, although not a fortune, is more than I'd like to spend.
Posted : 03/06/2012 12:57 pm
Hope and Superstar's adaptors are for a full-thickness 9mm axle so you would have to add your own axle to suit.
Posted : 03/06/2012 1:05 pm
That's not a bolt up option that's a though axle. Does anyone do a 9mm bolt up through axle?
Posted : 03/06/2012 1:15 pm
