Ok stupid question - my M4s new bled as slightly leaky from the banjo when they arrived.
Can I use any DOT 5.1 fluid - LBS doesnt stock it but would any motor factor fluid do the job?
Got the rear caliper on and running and it feels excellent so far.
I use normal brake fluid (the stuff we use to build F1 cars) and that works fine, as long as it's new fluid as an open bottle will have absorbed water.
Thankyou - just got to get over my first bleed experience then 😀
Where are you? I'll happily give you hand if you're near Reading/Oxford
Unfortunately way too far away in the Highlands of Scotland.
But absolute top class offer which is much appreciated though !
im in aberdeenshire if you need help ?
Thanks for the offer - may drop you a line if I get stuck !
Its the new style lever so hoping its straight forward. But got to factor in numpty mistakes from me.
Ok that was a pain.
Bled them first time - got them working nicely then found fluid coming from the banjo again.
So started all over after some swearing and really made sure the banjo nut was ultra tight this time.
Still not 100% sure its ok (more paranoia) but they work nicely - really nice brakes, feel great and cant wait to put them to proper use.
Presuming we're talking about the bolt that goes into the caliper here, have you got a copper washer either side of the banjo fitting it passes through?
