Bleeding elixir 5 :...
[Closed] Bleeding elixir 5 🙁
Does anyone actually bleed this brakes and become successful? ....have this for a year and never a month goes by that i dont bleed this but still ended up mediocre or ok (ish) kinda bleed .
Posted : 23/11/2013 8:00 pm
Never really had an issue, got two pairs and bleed occasionally when required.
Posted : 23/11/2013 8:04 pm
This is a decent guide
http://www.pinkbike.com/news/tech-tuesday-bleeding-avid-brakes-2010.html
Posted : 23/11/2013 8:06 pm
It may not be a problem with how you are bleeding them, it could more be an issue with the internals of your brakes.
Because dot fluid is corrosive it can perish the rubber o seals and internals of your brakes, it may be worth rebuilding them with a new internal kit if they are more than 18months old.
Posted : 23/11/2013 8:14 pm
I used to bleed them with a brake block in place of the rotor, now I just leave the wheel in place, rotor protected. Get much better results. 10 mins each end, leant from the video on the Avid site.
Posted : 23/11/2013 8:18 pm
What eewan said. I struggled for years with bleeding mine then replaced the internals and they work perfectly. Available for £15 from Germany - mail me if you want details and I'll dig it out. Easy job to replace them too.
Posted : 23/11/2013 8:48 pm
From my experience (4 different sets across 3 different bikes) it's just a case of taking your time with the bleed process & following the SRAM videos to the letter.
Been running Elixir's for about 3 years now & have found them to be pretty reliable. I'm aware that there are plenty of folk who've had issues.
Posted : 23/11/2013 8:52 pm
