Bike work stand.......
[Closed] Bike work stand....ttoo cheap must be crap??????£15.47 Delivered
Saw this on Amazon..
can only find the one review on amazon..
seems really cheap so im guessing its going to be crap..
[url= http://www.amazon.co.uk/dp/B008UOXEUG/ref=pe_208761_33708441_pe_vfe_dt3 ]STAND[/url]
wasnt sure if anyone had this style of stand, who can offer any more reviews.
cheeers guys
Posted : 03/01/2013 8:18 am
Not really sure what goes where. Looks unstable though
Posted : 03/01/2013 8:23 am
i "think" the bb sits in the little cup half way up the upright
Posted : 03/01/2013 8:30 am
Yep - BB in lower cup, top of down tube in upper one & the bit in between is used to hold it in place.
I've seen a much more substantial one in use so cant actually comment on the one in the picture.
Edit: The Topeak one below which is £100 ish:
Posted : 03/01/2013 8:45 am
same as the decathlon one that
Posted : 03/01/2013 8:46 am
Looking for a cheap stand and went with this one.Once it was built up it sat a little squint on the ground and it's a bit of a pain to get back wheel off because of the design of the stand.Apart from that I love it sits at a good height and the stand can take a fair bit of force before it moves.Folds up quite small as well pleased I bought it.It is a cheap stand but so far seems to be a good one.
Gotta be worth a punt for £15!!!
Posted : 03/01/2013 9:16 am
Used to have one of that style ages ago (although the clamp went over the BB area rather than downtube as that one looks like). I found it OK although if you have exposed inner gear cable running down the downtube they can get compressed so make adjusting gears a PITA. The only other downside is they're not height adjustable (at least the one I had wasn't).
Happy with my Feedback sports posh stand but was actually looking at getting a second stand like that as it's a bit less faff for washing (especially on bikes with a dropper post as I can't clamp it properly on my stand), they also give a bit more support when working on the BB. Would be interested to know how stable that £15 jobbie is...
Posted : 03/01/2013 9:17 am
The BB holder is too small and so I hacked a bit off it. The hook to hold the downtube doesn't inspire 100% confidence. Had a bike slip out of the BB holder and so ziptied around the BB as well as the hook
Posted : 03/01/2013 9:43 am
i've used one that was similar in the past. found that they were ok but if your frame has a fat down tube then the spring loaded clamp may not fit around to secure the frame.
but for £15 i suppose its worth a shot.
Posted : 03/01/2013 11:23 am
I had a similar decathlon one for £25, but it had a big plastic ratchet strap (like race shoes, but about 3x wider), OK apart from it didn't work with bent downtubes or brake cables running under the BB.
Posted : 03/01/2013 11:28 am
