Hi, looking to get some custom stickers made, anyone know someone who does this sort of thing, the ones I have contacted don't even reply.
Binners had some made the other week.
spiral grafix in lancashire have done some stickers for me recently and were really good.
http://www.spiralgfx.com/
Cool thanks will get in contact.
Who have you tried?
slik graphics?
gil @ the bike shed?
Try contacting Gil at The Cycleshed. He does all sorts of stuff. Lots of the Retrobike crew, myself included, have used him.
if you do manage to get a reply from slik graphics (they were great in my case) they do excellent work.
this is a custom five decal kit based on the patriot sticker kit.
[URL= http://i876.photobucket.com/albums/ab330/Lummox1329/Snapbucket/DB0272B7_zps597a56d2.jp g" target="_blank">
http://i876.photobucket.com/albums/ab330/Lummox1329/Snapbucket/DB0272B7_zps597a56d2.jp g"/> [/IMG][/URL]
I tried silk & a few local
Will try gil,
Orange looks good
if you have no luck then I may be able to sort you out.
email is in my profile
Sam
I got a quick response from Slik... Mind you I sent them full mockups that they could have gone straight to print with, and source images and dimensions and that so they could choose to rebuild the design from scratch if need be, so it's probably an easy job for them. No offence to the OP but I wonder how many ignored inquiries are along the lines of "I need some stickers, sort of a bit like the ones off a '90s Kona but with extra cats"
The whole sticker/decal issue has been done before (by me), the only place they belong is carefully peeled off everything possible, and chucked in the bin!
Did you really get a Greggs sticker made?
No offence taken , I want a set of decals for a carbine 275, intense do not sell them at the moment, what's best way to approach this.
Northwind were or how did you do mockups?
I've used Slik and the quality is excellent.
You probably need to give him a call if you haven't had a reply though.
fair play to you! ๐ฎ
Best decals are the water transfers that go under the clearcoat.
I do my powdercoated frames that way.
stickers without a clear over them peel and look tatty after a bit, but vinyl stickers are too thick to go under the clearc.
[url= http://revanchebikeco.wordpress.com/2014/05/15/bicycle-decals-painting-and-water-slides/ ]more words on the subject[/url]
Getting fed up with chasing Slik. It's pretty lame!
Will try Gil.
I got some made up by http://www.cca-signs.co.uk Crawford Carrick Andersons company none the less.
Gil M every time !!!!!!
Slik best avoided .... I can handle a bit of a wait but to be told over the phone repeatedly yes I'll confirm artwork tonight then repeat for few weeks !!! I gave up ๐
I've had one set from Slik before and it was pretty painless. This job should have been an easy, open file, change colour and make. Got the usual promises but then nothing.
