Better Jones bars.
[Closed] Better Jones bars.
[#9700245]
I've not seen anyone else using these. I really like them and just wanted to share as I know there are other wierdo-bar fans on here. Surly Moloko
740mm wide, they don't rotate in the stem upon hard landings and you don't have to have a silly length stem to use them.
Crap photos though
Posted : 02/12/2017 10:39 pm
my jones dont rotate on hard landings though , .... that fact they are 20mm wider makes them better ?
Posted : 02/12/2017 10:41 pm
You need to land harder 😉
Posted : 02/12/2017 10:45 pm
Mine did, I had to way overtorque the stem bolts to stop it from happening. My hands in the rearmost position were way behind the stem clamp and the moment caused from landing drops kept shifting them.
Posted : 02/12/2017 10:47 pm
My wide carbon loops don't move under hard landings and don't weigh nearly 0.8kg for a set of bars 🙂 the moloko look interesting but mentally expensive for some heavy gaspipe
Little bit of carbon grip paste, even on alloy loops and no need to over torque any stem bolts at all
Posted : 02/12/2017 10:48 pm
That tape is great for weeping callouses (callis???)
Posted : 02/12/2017 10:50 pm
newp mine dont .... but i have broken 2 sets of carbon forks.
perhaps your stem is out of tollerance .
Posted : 02/12/2017 11:03 pm
 ton
my jones bars have never moved in the stem........and i have owned lots of jones bars.
Posted : 02/12/2017 11:13 pm
Not a thing. Are you sure you're capable of building a bike? Maybe you should take it to a decent shop.
Posted : 03/12/2017 1:18 am
How are you finding them to ride?
Posted : 03/12/2017 1:32 am
Wow, they are giving the old Titec H Bars a run for the Ugly Cup competition. Saying that I think Jeff has released some new ones that are contenders as well.
Posted : 03/12/2017 8:26 am
I've seen one set of the Moloko bars "in the wild", the guy seemed happy enough with them.
Not had my Jones bars move and they weigh under 300g not nearly 800g!
Posted : 03/12/2017 9:32 am
Just noticed the large spacer at the crown of the fork, is this a feature or the more recent models?
800g for a bar? No thanks!)
Posted : 03/12/2017 10:26 am
hah, yowch. The wrath of STW.
They give you a bit more of an elbows out position than the Jones bars which I've been getting on better with in the rough stuff.
Posted : 03/12/2017 10:27 am
All while weighing as much as a small sun ?
Posted : 03/12/2017 10:29 am
That bar weighs as much as you do Retrodirect.
Posted : 03/12/2017 11:07 am
FTC- Jeff recommends a 1.5mm spacer there iirc.
Need to go check the build sheet to be 100% sure
Posted : 03/12/2017 11:36 am
what's the point of those daft looking forks? do they have a suspension effect?
Posted : 03/12/2017 2:01 pm
As a long term Mary bar user, mainly into bikepacking, those bars look interesting - but not at that weight and price.
Posted : 03/12/2017 2:11 pm
seosamh77 - the opposite. They’re very stiff so don’t flutter at all under braking.
Posted : 03/12/2017 4:34 pm
