Best singlespeed co...
[Closed] Best singlespeed converter kit?
[#2001945]
Have had my Klein Attitude hung up in the garage unloved for past year due to riding some of my other fleet.
I've decided to set it up as a singlespeed for the approaching winter. I currently have a middleburn duo chainset on the front, which will be ok with the outer ring off. Inner ring is 32t. Current hubs are hope XC.
I don't want to buy new hubs, so which rear hub converter should i go for? Also, as the Klein only has the mini horizontal drop outs I assume I'll need some way of keeping the chain at the correct tension, some sort of 'singulator'.
Any thoughts on easiest/best way to convert would be appreciated.
cheers
Posted : 18/09/2010 9:56 am
converted my kona about three months ago with the on-one kit been spot on so far so i would go for that one
Posted : 18/09/2010 11:16 am
-1 for DMR singulator
+1 for Rohloff one (although a lot more expensive)
Posted : 18/09/2010 11:25 am
I ride my Cotic Soul mostly singlespeed.
I prefer an unramped chainring, but it's not too important.
I use a shimano DX sprocket with a load of old cassette spacers, but you can get DMR sets of sprocket & spacers.
I also use a DMR Tension Seeker when I need a tensioner (push up, always) and have never had a problem with it.
Any old chain.
If you end up with a 1/8 sprocket you will need a 1/8 chain but you can still use a 9spd chainring, although your tensioner might not fit.
Posted : 18/09/2010 12:18 pm
+1 rohloff
Posted : 18/09/2010 12:26 pm
For those who use the Rohloff tensioner:
Do you get chain slap at all? Ive used a DMR sts (the bolt up one) obviously you dont get chain slap with that, but do you with the spring tensioned rohloff?
Cheers.
Posted : 18/09/2010 12:35 pm
I'm using the DMR spacer kit but a normal 3/32 setup - Shimamo 9sp chain, Blackspire DH 32t ring and an 18t cog I robbed from a 9sp cassette. Before you buy a tensioner, see if you can get a magic ratio with a suitable combination of ring sizes. Try this online calculator. You will need to measure the distance between you BB axle and rear hub axle (effective chainstay length). [url= http://eehouse.org/fixin/formfmu.php ]Magic ratio calculator[/url]
Posted : 18/09/2010 1:12 pm
