Best rear suspensio...
[Closed] Best rear suspension design is....?
I don't have much experience of full suspension bikes as only riden single pivot and FSR. Prefered the FSR as i felt the single pivot was too susceptable to pedal bob even when the shock is in pro-pedal mode.
which suspension system is, in your opinion, the 'best' for all round type riding?
Posted : 02/02/2010 4:27 pm
 ton
very grey area.
knees, or tyres are the oldest.
Posted : 02/02/2010 4:28 pm
Commencal contact system
Posted : 02/02/2010 4:33 pm
For me it's the DW Link used by Turner and Iron Horse etc...
Posted : 02/02/2010 4:38 pm
 mt
Four bar linkage of most designs.
Posted : 02/02/2010 4:42 pm
In STW land it is whatever your own current bike has. Therefore the best system is the Santa Cruz/Intense VPP
 nonk
not that many bad ones anymore would perhaps be a better way to look at it.
apart from the orange 5 cos thats rubbish 😉
Posted : 02/02/2010 4:45 pm
URT*
*joke.
Posted : 02/02/2010 4:46 pm
depends what you want,
lets take the horst link (specialized)
you could build the orginal pateneted verion and it'd be crap
The pitch and previous incarnation of the enduro were borderline identical, yet spesh admitted the pitch was a refinement in terms of suspension.
Nicolai's take on the horst link is entirely different to specialized (instant center moves foreward, not back).
giant built the NRS with the same configuration of pivots, but the vertical distance between the link and the dropout meant chain tension locked the shock out, but wouldn't have worked with more travel as the chain growth would have been too much.
Go on some test rides, (and take a shock pump!) there isn't a "right" answer.
Posted : 02/02/2010 4:47 pm
Surely it depends an awful lot on the actual excecution? That and how good the shock attached to it is at ironing out the bad points of the suspension design and highlighting the good points
I'd like a go on a DW link for the antisquat characteristics. An FSR does seem to sit its travel rather a lot when going up steeper hills. If I had a lockout or even a propedal adjustment on my SJer then it probably wouldn't be a real issue, as I don't and 'only' have a brain, it is an issue
Posted : 02/02/2010 4:51 pm
Not really such a thing as 'the best'. All have weak points - you have to decide which is the best [i]for you[/i].
of all the sus designs i've ridden this felt most like a hardtail. no real bob with pro-pedal on. no jacking up with heavy braking. really stiff and felt solid.
i just don't have the money or desire to part with 1700€ for the frame and shock.
besides, i love my HTs
Posted : 02/02/2010 5:04 pm
the next one.
believe the hype.
Posted : 02/02/2010 5:25 pm
Personal preference?
I love the way my NRS seems to lock out under acceleration and still is fairly supple over rough stuff. That said, over really rough stuff I still prefer the way my single pivot felt.
Horses for courses?
Posted : 02/02/2010 5:30 pm
Pivot height has a significant bearing.
4 bar vs single pivot does not except o rbraking on long travel designs.
No doubt plenty will argue with the above, I hope most will accept that m'fers promulgate huge amounts of twaddle in order to convince punters their design is the best.
Posted : 02/02/2010 5:32 pm
jackthedog - Member
Not really such a thing as 'the best'. All have weak points - you have to decide which is the best for you.
Is the correct answer.
There are not many basic types - single pivot / swinging fork, double wishbone with various names and sliding member ( never seen it used). There is then also the question of how you drive the shock - directly or thru a linkage and how you make that linkage behave.
Moving the various pivot points around alters wheel path so alters how it behaves - even with single pivot. With a double wishbone type setup there is huge variety in how long the wishbones are - from an inch or two to aver a foot.
All have compromises of one sort or another.
edit:
is also correct - as is the propensity of gullible fol to believe the twaddle.
Posted : 02/02/2010 5:36 pm
Really really really high single pivot with idler pulley or jackshaft. Anything else is compromising somewhere.
Posted : 02/02/2010 5:40 pm
They're all a compromise, why do you think there's loads of options around rather than one that is the best and everyone use it?
Posted : 02/02/2010 5:47 pm
Because people are stupid and buy whatever system is being hyped?
Posted : 02/02/2010 6:00 pm
whatever dave turner says (it changes every year or 2)
Posted : 02/02/2010 6:07 pm
The one that is set up the best.
Posted : 02/02/2010 6:09 pm
So you don't think that'll compromise "weight" or "maintenance" at all?
Posted : 02/02/2010 6:16 pm
And efficinecy Brant - extra friction in that idler wheel
Posted : 02/02/2010 6:18 pm
aye whatever, TJ, whatever... 😐
Posted : 02/02/2010 6:25 pm
To be invented...
Posted : 02/02/2010 6:26 pm
VPP FTW 😉
Posted : 02/02/2010 6:28 pm
I've thought about this. It would have to be a nanomechanical self-configuring system capable of moving pivot, adjusting travel, compression and rebound instantaneously. Also capable of changing wheel size, tyre tread pattern, width and pressure on the fly. Available 2020.
cf the skateboards in 'Snow Crash' by Neal stephenson
Posted : 02/02/2010 6:30 pm
the design that suits your riding of style and doesn't require constant maintenance. Different designs suit different people so there isn't one best design IMO.
There's compromises on every design out there bar none. Nothing is perfect. Just ride the one that you like and stop talking about it instead.
As the great onza sticker from the 90's used to say
[b]"shut up and ride"[/b]
Posted : 02/02/2010 6:44 pm
nicest designs I've ridden are:
Stevenson six bar
Ellsworth ICT system
new marin quad link
but for simple maintenance/ease of use/general everyday riding a good single pivot system is still the best to me in most situations.
Posted : 02/02/2010 6:50 pm
 ton
so after all that, the answer is............a very grey area.
knees and tyres are very good.
Posted : 02/02/2010 6:54 pm
Yep, i'm a fan of single pivot's too, simple and lightweight.
Main thing is to ride the bike you are most comfortable with/feel most confident on, there's a lot more that goes into a good bike than just purely the rear suspension design.
Personally liking the feel of the Marin Quad link. Really does feel "bottomless" with the rising rate, and the zero chain growth beyond the recomended amount of sag means no kickback. Cant say Ive noticed any adverse pedal induced bob either. Cant see any cons of this system, but I'm sure theres something? It cant actually be perfect can it?
Posted : 02/02/2010 6:56 pm
It is the system on my Fuel EX9 with the Active Braking Pivot. It must be, they didn't lie to me did they?
Posted : 02/02/2010 6:58 pm
I really liked the performance of my Idrive 5... Extremely heavy, at least partly because of the Idrive but it rode lovely, and no mucking about with pedal feedback etc. Didn't have a lockout on the shock, didn't need one. But I'm not totally sure the extra weight and complexity is worthwhile
Posted : 02/02/2010 7:04 pm
No pivot, flexing chain stays, 100mm travel,
C
Posted : 02/02/2010 7:20 pm
Well that doesn't look to be the case on the graphs I've seen.
Anyone interested in suspension would probably be interested in downloading Linkage, from http://bikechecker.com/
Quite a steep learning curve, but the web library there has a host of designs mapped into it, and you can see a lot of stuff, and how linkages and pivot points affect suspension travel and action.
Posted : 02/02/2010 7:23 pm
 wors
i'll go with that too.
Posted : 02/02/2010 7:26 pm
 ojom
I like bikes. I like them more if they go boing.
How they go boing does not really worry me. Just that they make me smile.
Posted : 02/02/2010 7:40 pm
If you really wanna know, get the last 4-5 issues of Dirt and read the articles about suspension tech. Then read them again. Then keep reading til you understand them. Then you'll know. Maybe.
Of those I've ridden, I like linkage driven single pivots (yes! like my Yeti). Funny but more & more manufacturers seem to be using variations on that method lately. Even Cannondale and Orange, who seemed to stick with the straight single pivot until now...
Horses for courses though, as with all things mtb.
Posted : 02/02/2010 7:47 pm
i don't like single pivot designs, for exactly the same reason that i think they're quite qood.
single pivot designs lock out more than most 4-bars under braking, which i don't like. but the benefit of brake lock is that the compressed/locked rear wheel balances some of the nose-dive at the front under heavy braking - which makes them feel less panicky if you grab the brakes.
i've decided to settle for a more active system, even if it means a bit more panicky nose dive under heavy breaking, so i like horst link 4-bars.
(i do like the simplicity of single pivots, but they can get a bit brutal on long descents)
the trek abp is simply a very clever way of sidestepping the horst link patent - as it allows the brake calliper to be mounted on the seatstay.
Posted : 02/02/2010 8:17 pm
Dirt Magazine has published some very informative articles about why pivot placement is important and it's made for interesting reading.
I do agree that there are few munters out there these days, but there are quite profound differences in how a bike feels in certain conditions. Both my suspension bikes are broadly speaking Four Bar bikes, however they ride completely differently.
The Horst link bike feels very plush and never seems to have an issue with traction, however it's prone to pedal induced squat.
The Quad Link bike is stiff under pedalling and always feels controlled, but the rear wheel spits traction suddenly and the suspension bobs when using the granny ring.
Posted : 02/02/2010 9:00 pm
 LoCo
Interesting thread!! This will be a can of worms!
Really it's all going to depend on what your doing, how and where.
I don't think you get any really bad bikes these days, well maybe 😮
I'm not going to mention names!
The way the suspension is setup is the main factor for the vast majority of people most of the time.
Posted : 02/02/2010 9:21 pm
Ooh, I wish I hadn't clicked on that linkage weblink from Brant. May have to buy the software and waste loads of time playing with it...
I'm very much of the opinion that suspension set up is vastly more important than the actual design. I'm sure so many people don't get this right. Further, having just thought about it I own or have owned single pivot, faux-bar, VPP and DW and I like(d) them all although all have various pros and cons. Hard to compare exactly as the DW has 8" travel and the faux-bar 5.5". I do believe that shock technology (specifically RP23) has opened up a load of designs which would have been rubbish to ride a few years ago.
Posted : 02/02/2010 9:29 pm
Compared to what, a hardtail? Any suspension system is going to have bearings and extra metal. The only system which is definitely going to be lighter/lower maintenance is SP, but then it won't ride as well, which is the point is it not?
Posted : 02/02/2010 9:44 pm
treks abp is pretty neat in terms of isolating stuff...wait for shock technology to advance a bit more it'tl come down to geometry and a clever little processor in the shock
Posted : 03/02/2010 10:42 am
awhiles - interesting, though my single piv did used to compress on braking, obviously, it never locked out or got harsh on alpine descents.
I may have to buy some Jr Ts and ressurect the old Coyote!
As composite suggests, wait for decent sensors and micro control to hit the shock realm and you'll see some pretty impressive advances, just like active suspension on track cars - yes you can create a car that works well without it, but with it you can create a beast that can do things that are just not possible without constantly variable parameters.
Will it make the bike more fun to ride? I'm not so sure.
Posted : 03/02/2010 10:48 am
 GW
thebikechain - Member
LBS of the year, eh?
Posted : 03/02/2010 11:11 am
I see no point in masking design problems in suspension design with tricky damping , active control or pro pedal ,,
there is no best design it's a compramise ,, whats good for a xc race wont be great on a non pedaly DH course
with the advent of hammerschmitt front thingies it's made the single pivot designers life luch easier as his ideal pivot placment( whereever that maybe) as he has only one ring to design around
the other reason why there is so many designs out there is the need for the designer to get around the huge number of patents out there,,
i think there is a lot of life in the single pivot design,, and with the new crop of linkages now letting the designer control the rate curve rather than being forced into the standard single pivot falling rate ,, single pivots have a lot going for them
Posted : 03/02/2010 11:22 am
bear in mind that suspension program is like wikipedia and can be changed by anyone, companies have a vested interest in making results fit their marketing, and ammetures might not measure stuff correctly.
Posted : 03/02/2010 11:33 am
Single pivot is the most trouble free but when compared to a Horst link it rides like a pig on stilts.
Nicolai do it best 🙂
Posted : 03/02/2010 11:39 am
I have a copy of linkage ,, and some of the files are a bit dodgy but i have found most to be very good,, and for developing your own design it's great wish I had it 10 years ago ,,
i know of a few people in the bike design world who have switched to this for initial design before going for it in the cad world ,,,
but remember GARBAGE in GARBAGE out ,,,,
Posted : 03/02/2010 11:41 am
worm can opened
Posted : 03/02/2010 11:47 am
[b]ade ward[/b]:
I understand that you have a background in this and, given the inevitable compromises forced on bike suspension design, wonder why you see no point?
Is there a reason to have, in simplistic terms, a complex suspension action (Whyte Plus 4, Horst, counter rotating 4-bar/VPP) and "simple" damping vs. single pivot and platform damping, a la Foes?
Posted : 03/02/2010 11:48 am
I think Brant should lay the cards on the table with some details of the Ragley full-sus....
Posted : 03/02/2010 12:00 pm
from the bikes I have riden (GF, Scott, Giant), i liked the Giant Maestro system, worked all the time, no feeling of bob etc
Posted : 03/02/2010 12:05 pm
honestly; hardtail.
Posted : 03/02/2010 12:19 pm
there's no Ragley full sus at the moment, though there might be some Nukeproof stuff coming 🙂
Posted : 03/02/2010 12:21 pm
in a word fashion,, all the obove designs have their merits,, and possisbly perform better in certain situations
but i would blame the DH market,, where often pedal feedback is not the main criteria of the design,, then the marketing man then feels all his range should look like the DH design plus they may have paid a lot of money for a patent licience and feel they have to justify it throughout the range
damping in my personal little world i think that high speed damping is for controling the wheel(unsprung) and low speed damping is for controling the body (sprung weight frame rider etc) and trying to control the pedal induced suspension squat with damping will effect it's performace in controling the bike in pitch and until we have the power to run a hydraulic pump and batteries for the black box full active systems are just dreams
Posted : 03/02/2010 12:58 pm
If you look at Turner bikes and the various reports that have come back from the 3x Flux rear suspension designs it's:
+1 DW Link
Posted : 03/02/2010 1:03 pm
I would say a Horst link, but I have limited experience of newer designs such as the DW link/VPP so will have to reserve judgement.
I do know the worst though: anything 'faux-bar'. Like any Kona, 2nd gen 5-spot. Unless you prefer your rear suspension to stop working properly when you apply the brakes that is.
Posted : 15/02/2010 1:28 pm
All I know is VPP, and yet the hills look greener in other camps...
....or is that what they want us to think!
Old MTB saying: If it ain't broke..................................flog it on STW and buy something new & shiny
Posted : 15/02/2010 1:40 pm
If any one system was significantly better than others then we would all be using it.
Comparisons from one bike to the next are invariably useless as there are too many other factors that are different, yet ignored.
This is one of many posts that is typical of someone who reads the magazines without applying their mind.
Posted : 15/02/2010 2:08 pm
[url= http://www.engadget.com/2010/01/09/cannondales-mind-blowing-simon-electronic-suspension-system-han/ ]We are getting closer to active electronic control. Not sure I'd have started with the fork to be honest.[/url]
Posted : 15/02/2010 2:15 pm
Pro-flex already tried that did they not?
Posted : 15/02/2010 2:25 pm
al' - faux bars are about as bad as it gets for brake lock. a lot of people don't seem to notice it, but most people haven't ridden a truly active system.
(the downside of an active system is that they're a bit more nose-divey when you grab the brakes)
Posted : 15/02/2010 2:31 pm
 ojom
GW:
No we aren't. Nor have we aimed to be.
The point of the post was that most people don't actually know what suspension design does what.
It's more important that they try a range and find one that they enjoy irrespective of what patent is on it.
Personally that seems like the soundest advice i can give people. If you like it, it's the right one for you. i don't have an engineering or design background but i like riding bikes not analysing how it's riding. much like driving. I don't 'need' to know how my engine works as long as it works.
Make sense?
Posted : 15/02/2010 2:35 pm
I wish someone would do some sort of video/CAD comparison, that explained & demonstrated the differences in a clear way. It all does my head in.
Posted : 15/02/2010 2:39 pm
My outgoing single pivot bike can not be dialed without some bob, even with pro-pedal on a RP23. The more air squeezed in the more it just ramped up and became more and more like a HT. I think single pivot suits a certain terrain (perhaps more rocky/ledgey slower chunk, steep), but for more XC with climbing, faster descents not so good, as you would get bob on the climbs, and then brake jack/packing up on the fast descents, with more front wheel weight.
The complex multi-link systems I've tried (Giant's Maestro and Niner's CVA) are efficient, firm, with no bob or need for PP. Tracked better, no bottomless feeling, and also a disconnected trail feel
As long as you realise what you're getting into, and it suits your riding, all's well and you wont be disappointed
Posted : 15/02/2010 7:31 pm
[pulls up a chair...][i] Tea anybody? Cream and sugar?[/i] [sits comfortably and reads on...]
Posted : 15/02/2010 7:41 pm
single pivot
Posted : 15/02/2010 7:43 pm
