Best plastic for ho...
[Closed] Best plastic for homemade front mudguard?
[#6724276]
I have several mtb, and its my intention to make some front mudguards for them, experimenting with shape and length.
I was wondering if anyone had any recommendations for the plastic to use, and thickness/grade please.
Its my intention basically to cut out shapes from flat sheet as i cant really do anything more complex, and I'd like some recommendations that are a bit more stylish than my milk carton lashups!
Posted : 23/12/2014 10:29 am
Buy a Marsh Guard/Fender bender and use that as a template.
I did cut one out of an old race race number which lasted quite well but in the end just bought more of the above - for the price it's not worth the faff.
Pro tip - run them upside down and you don't have to look at the nasty graphics/branding.
Posted : 23/12/2014 10:41 am
Mate made one out of a cheap plastic folder. Works really well and the plastics tough and flexible.
Posted : 23/12/2014 10:45 am
I bought some cheap plasticard from eBay and made a copy of my Marsh Guard for the rear.
Word of advice 1mm thick is too thick. Go with 0.5 or 0.75mm
Tom KP
Posted : 23/12/2014 10:51 am
I made one from an old Muck Off spray bottle, its got the right curve.
Posted : 23/12/2014 10:53 am
Not sure on the best plastic but there are loads of templates on-line for the flimsy plastic type. I did read people were using plastic folders from staples.
Another ideas I have seen is using housing gutter pipe.
Ecover non-bio laundry liquid bottles. Just the right curve, more substantial than milk bottles, and on special offer at Waitrose!
Posted : 23/12/2014 10:58 am
Thanks guys, i will explore those options!
Posted : 23/12/2014 11:51 am
karlsbug - Member
^This. I used an old 5l S***Shifter bottle, but any 5l plastic bottle - screen wash or sundry detergent types - will do.
Very proud of my UN-duro guard. TM
Posted : 23/12/2014 11:56 am
WH SMiths were doing 3 black folders for £2, enough to make 6 front mudguards. Here's mine, it's the same dimensions as as fender bender xl. Bit stiffer than fender bender but has done the trick so far.
Posted : 23/12/2014 12:12 pm
Paperchase sell polyboard in no end of colours.
Posted : 23/12/2014 12:17 pm
 gazc
plastic files work well - have some from work. if you're in newcastle you can grab one. also have a template image i can email you, print out full size and it works straight away
Posted : 23/12/2014 12:40 pm
Hi Gazc,
I have emailed you! Thanks
Ian
Posted : 23/12/2014 1:14 pm
Hope it's not going on a Santa Cruz
Posted : 23/12/2014 1:18 pm
No SC for me, but it will be on my Cube and YT
Posted : 23/12/2014 4:09 pm
plastic place mats cheap as chips and can get some funky designs
Posted : 23/12/2014 4:21 pm
The plastic from folders is polypropylene - can be bought from Ebay in sheets too. Works very well for mudguards.
Posted : 23/12/2014 4:30 pm
Begs the question how they have the nerve to charge £10 for one and who is stupid enough to pay it.
Posted : 23/12/2014 4:39 pm
I've used spare bits of guttering & 2ltr coke bottles in the past, not necessarily at the same time 😉
Posted : 23/12/2014 4:47 pm
As already said, Mucoff bottles work pretty well, just traced around a marshguard with a sharpie to make this one...
Posted : 23/12/2014 5:57 pm
I downloaded a PDF template, printed it off transferred it to a £1 tesco folder and cut that out, used a hole punch to make holes for cable ties.
Works perfectly and looks almost as professional as the paid for versions.
Email me at: unovolo at gmail dot com if you want a copy of the PDF template.
Posted : 23/12/2014 7:10 pm
^^@Karl33to exactly like mine.
Posted : 24/12/2014 12:55 pm
 nach
Polypropylene. I'm pretty sure it's what most of the bender fender ones are made from (specifically a product named ViPrint), and it's available down to 0.5mm thick sheets. It's strong and incredibly chemically resistant, packaging manufacturers tend to use it whenever they need a living hinge (e.g. the top of a tictac box).
Stationery binders can be a readily available source of small amounts, but when I've got it that way it's been 0.8 - 1mm thick and harder to work with. Try ebay maybe? 0.5mm is plenty strong enough if you can get it, and easy to cut with scissors.
Posted : 24/12/2014 4:57 pm
As daft as it may sound, you could try cutting out templates from an old camping mat.
They're fairly pliable, cheap and waterproof.
Posted : 25/12/2014 1:21 am
