Been trawling around for a service kit for my Rebas. Not sure what I am getting is correct. Can anyone help ? I have a set of 100mm 26 inch SL with dual air and motion control, 32 mm I believe. I am loosing air out the negative side, so that's the important bit, to get the new o rings etc.
Here.
http://www.ebay.co.uk/itm/Rock-Shox-Reba-Race-O-rings-Seals-Crush-Washer-kit-/181411703562?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2a3cfaeb0a
All the O rings and crush washers you'll need. If you want to belt and brace it, whip the valve cores out of a pair of old schrader tubes and swap them for he ones in the pos and neg air shaft.
Have you got Wiper seals and foam glide rings? If not
http://www.ebay.co.uk/itm/RockShox-32mm-Seals-FREE-Crush-Washers-Recon-SID-Reba-Pike-Tora-Revelation-/231231764960?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item35d67cb9e0
Thanks Scapegoat, that's great. Off to order them now.
