My rear suspension bolts are loose already after just a few rides, what Loctite should I use on the threads?
Loctite 242 😉
2nd Joe G. Really useful stuff.
Make sure whatever it is you end up with is "Low Strength" Loctite make stuff that goes all the way to permanent 😥 They also make cleaner for use on the threads which I don't see getting used often.
D.
The Loctite 242 and 248 are both 'medium strength', but Davesport has recommended using a low strength version.
Can anyone clarify which should be used?
243 medium strength will be fine
Loctite 222
Loctite 222 Low strength, general purpose Threadlocker, Breakaway torque 6Nm
Your benefits:
?Ideal for low-strength threadlocking of adjusting screws, countersunk head screws and set screws
?Good on low strength metals which could break during disassembly, e.g. aluminium or brass
Technical Data:
?Maximum thread size: Up to M36
?Strength: Low
?Breakaway torque M10 bolts: 6Nm
?Fixture time steel: 15 min.
?Fixture time brass: 8 min.
?Fixture time stainless steel: 360 min.
?Service temperature range: -55°C - +150°C
?Pack sizes: 10ml, 50ml, 250ml
Cheers people. Found some Loctite 243 I had in my toolbox, used that, that ok?
omg no!!!!!!!!!!!!!!!!!!
The correct torque?
243 is fine; same strength as the 242 but less runny.
What you've got should be fine but I've never needed anything stronger than 222 on a bicycle.
