Best eMTB of the Ye...
Best eMTB of the Year: Cotic Rocket
The thing that gets me most about that video, in an increasingly cynical world, is that Frameworks got Austin Hackett-Klaube from Specialized to do the back to back riding, because Neko was injured. Love it when people work together to try and understand and progress the riding rather than just sit in their brand silos sticking to justifying what their company is trying to sell.
Posted : 09/01/2026 5:26 pm
Posted by: jameso
Do you think it doesn't matter or we can't feel differences in this area, or a reviewer is making this stuff up? Genuine Q.
I think that often, somewhere between the design department and the marketing department, something ends up getting lost in translation.  And the marketing department convey this misinformation to the cycling press (and it seems to be both road and mtb) and then it gets repeated until something new comes along and the cycle continues.
This was a joke blog post from 2008 that stuck with me because it summed up the cycling press at the time (the other bit that always sticks in my mind is "Five Ways To Keep Your Beer Gut Off Your Top Tube" but the less said about that the better). And honestly, it feels like the industry hasn't really come that far.
There are still marketing people saying stuff that is flat our wrong and journos who just repeat it without ever once going, 'Er, hang on...'  And people who pick up on this and then use it as part of their buying decisions for years after.
Personally I think mtb design is like pretty much any other engineering.  Every decision you make is a compromise and better performance in one area leads to reduced performance in another.  And that's before we get to the most important part of the equation which is the rider.
Even compared to motorcycles, with mountain bikes the rider's 'style' has a massive impact.  Personally I never really noticed differences in frame stiffness that much but then I've always run my tyre pressures lower than I should (according to conventional wisdom and since I've discovered inserts that's only gotten more extreme) and I run my suspension much stiffer than I should.  So I suspect I'm putting up with the downsides of lower tyre pressures because then I don't have to worry about any flex or lack of flex in the rest of the system.
Laterally stiff but vertically compliant (and variations on this theme) was a thing for a while.  Hence the blog post taking the piss out of it.  It ignored that fact that the energy you put into a spring isn't 'lost'. A steel frame being flexed is a spring, not a damper.  If the spring get's energy put into it then that energy is coming back again.  And when it does it tends to find it's way to the wheels.
The lateral stiffness in full suspension frames has at least as many misconceptions around it.  There are all those Starlings with their skinny little seatstays that many people seem to think woks absolutely fine so I'm skeptical about the perceived downsides a flexible frame from that point of view as well.  But then you also have people who have never ridden Starlings criticising them because  'they must be so flexy'.
So no, I don't think lateral stiffness is important, at least as long as it's not causing the bike to not function.  Or rather, it is important but not in terms of making the bike better or worse because so long as it's within the working limit it's just another compromise that has to be made.
Posted : 09/01/2026 9:13 pm
There are all those Starlings with their skinny little seatstays that many people seem to think woks absolutely fine…”
If you read enough reviews etc about Starlings you’ll find people consistently saying they’re brilliant on natural trails, particularly off-camber stuff, and you’ll find some people disliking how they feel too flexy in a bike park.
And on the other end you’ll find reviewers saying how great the old Pivot Firebird was for smashing berms at pro race pace but that it was too stiff for most riders compared to other similar bikes, which make it harder to ride.
Frame flex definitely matters, it’s not black and white and it’s a case of horses for courses.
It is interesting to think how many e-bikes have been made by fattening up downtubes and BB areas vs the normal bikes they’re based on - and how those bigger cross-sections will make for a much stiffer frame.
Actually on that subject I was riding home the last two days on my ebike and there’s this one downhill into a rooty braking-into-a-corner bit and it dawned on me that this bike doesn’t feel any/much smoother on that section than the singlespeed hardtail I rode for the commute the day before. So that’s a big fat alloy ebike frame and 170/157mm of suspension vs a steel 160mm hardtail. I’ll see what I notice next week, it’s a brutal climb without gears but I’m trying to do it once a week in the hope of cleaning it at some point…
Posted : 10/01/2026 12:27 am
 mboy
Apologies, had told myself I'd stay away from this thread... But like a moth to a flame! You can blame my GF for her shit TV choice causing me to kill more time on here...
Posted by: BruceWee
No it didn't... It ignored nothing. Yes "VCLS" were the buzz words in the road market for a while, at least until they all started coming with clearance for 28c tyres or larger... Nobody was ignoring that the frame material wouldn't want to return the energy. They were actually counting on some give, you know, just like a spring, to move with the bumps, knowing it would then be returned afterwards... Or at least the designs without some kind of damper inserted in there were... Anyway...
Posted by: BruceWee
And then you have people that have owned Starlings, got pissed off with the feeling of the back end wanting to overtake the front, the tyre rubbing inside the swingarm, the cranks rubbing on the outside of the swingarm... Caveat emptor... Mine was an early one, and I'm also probably 10kg heavier than the average rider. I'm aware that people out there love them, and better riders than me have won races on them. But it just proves the subjectivity of it all more than anything!
Posted by: BruceWee
Captain Obvious is impressed! 👍🏻
Posted by: VanHalen
thats not what racers are doing though. they are adjusting lateral frame compliance with bolted in plates.  longevity isnt a need for them though as they`ll get new bearings every race. do that on a 'normal' bike for sale and manufacturers get a roasting and frames will snap.
It's often useful to see what the racers are doing to get performance advantages, but the reality is they will often go too far with something (bike geometry for instance) to then start dialling it back to get to a point not that far from where they were previously quite often, but at least they are then able to rule things out... Don't get me wrong, there's been DH race bikes that have been too stiff/unforgiving, but there's also bikes that have been too flexy too...
Posted by: jameso
At the extremes, a 100% rigid frame and fork would be horrible to ride. But a frame that's too flexible wouldn't be possible to ride.
So the conclusion has to be that some flex is a good thing, there is an element of flex that is good and how much variable and subjective. There is no right answer but there will be a consensus of general opinion.
It's this general consensus of opinion that is causing the wildly varying opinions it would seem! You'll know James, a bike designed purely by committee will have no identity, no real purpose, it'll just be a hotch potch of compromises that mean very little to anyone... Its blandness will nullify any passion and yet more than likely it will be a sales success because it is so inoffensive (and/or the marketing budget is 10x the development budget for it)... Vanilla Ice Cream basically...
And on the other hand, a bike so obviously single minded and as much of a signature for a brand as the Rocket is for Cotic, will absolutely enthral a handful of loyal diehard brand fans, and yet the vast majority will dismiss it purely on the grounds of looks without even having considered any of its potential redeeming features much less having ridden it... Or Marmite in other words...
If we are to come back to the point above about DH racers experimenting with bike setups and even their frame flex and take a look more deeply into the the entire bike as a "system" that occupies space between the riders hand/feet/arse and the ground, then I think that given we are discussing full suspension mountain bikes being ridden predominantly on quite rough terrain here, we're all in agreement that a level of "give" is a good thing... How you get that give and what it looks like, is the $6m question...
Now we've seen people experiment with flex pretty much everywhere on a bike over the years... I've been riding since the early 90's, so I remember when the Girvin Flexstem was being sold as the best solution for absorbing some of the terrain beneath you, and how ineffective they were! Prior to that, the only solution was to run thicker, softer grips though... And then we had suspension forks with 50mm of elastomer damped travel which suddenly seemed like the height of technology by comparison!
Fast forward a number of years... MTB's have learnt a lot from motorcycle design... Geometry has progressed somewhat, suspension has proper springs and dampers both ends on most longer travel bikes, and fork diameters have increased to provide a level of stiffness that whilst not as stiff as a motorbike's forks, is generally at least stiff enough for the average 20kg DH bike underneath the average 80kg rider being chucked down a mountain side... Frames have got significantly beefier too, mostly for the same reason. And then of course, wheels have got bigger, which has brought in a bit more flex whether it was needed or not, but certainly the benefits of bigger wheels tend to outweigh the negatives. But it does mean that where Nico Vouilloz was experimenting with lower and lower spoke tensions on his 26" rimmed DH bikes as your typical 26" wheel was really quite stiff and unforgiving if it was actually strong enough to survive a DH run, a 29er wheel is inherently that bit more forgiving... A lot of people have actually confused this for being undesirable, and hence the massive rise in sales of carbon 29er MTB wheels, which for anything other than XC I firmly believe still take more away than they add in just about every occasion. But it's yet another area that people can experiment with flex in the "bike system"... And then of course, there's the tyres... Arguably the single most important thing on the bike, as the tyres are the only points that contact the ground. And yet there's still so much heresy and conjecture on the internet as to what is "best" still (I've spent years working for a major tyre manufacturer, I know what tends to work for the pro's and why, but also why a average rider can't or shouldn't run the same high pressures the pro's run too as they simply aren't riding hard enough!), but just like arseholes, everybody's got an opinion on the matter, and they never stop to question it!
I know people who've bought a steel frame because they wanted compliance, then fitted super stiff carbon rimmed wheels to it along with tyres fitted with DH tyres inserts in, and then wondered why their bike rode like an unforgiving POS! A bit of frame flex isn't going to undo the work of an overly stiff and unforgiving wheel/tyre setup, not is it going to make up for poorly setup/serviced suspension either.
Posted by: chiefgrooveguru
I've generally reached the point I can't be bothered arguing online about complicated things because the world is very complex and most people like to simplify it too much, sometimes based on a lack of technical understanding and sometimes based on an assumption that if they can't tell a difference then clearly no-one else can. In recent years I've realised that I'm a bit different and I notice more than most, for better or worse...
From experience, I'm absolutely 100% inclined to agree with you... People will invest money into things that reinforce their beliefs, and then they will invest significantly more emotion into defending their purchases afterwards too... A guy I know locally I've ridden with occasionally, engineer (for a company that supplies the MoD no less, he's a very, very clever guy), quick rider and got some skills on him too... He absolutely has bought into the lighter and stiffer is better for everything mantra! But beyond that, he won't run his tyres above 14psi, and insists on running tyre inserts that reduce the air volume inside his tyres by about 80% too... His bike is damned light... So light that even at about 75kg he snapped his bling bling Titanium crank on a rock last time I rode with him! But it's a stiff, unforgiving mess too... His is the most extreme case I've come across recently, but there's plenty of others I know that simply just don't understand that the bike is a system and behaves as such... It's not so bad when people simply admit they don't know much about their bikes setup (I know several people a lot faster rider than myself, one of them a multiple national champion and a good friend of mine too, who literally couldn't tell the difference between one tyre and another wildly different one in use, or how to set their suspension up to even a base setting, or even how to index their gears, but f*** me they can ride a bike fast!), but it never ceases to amaze me how many amateur experts there are that will argue their ignorant opinion til they're blue in the face given half a chance!
Being able to notice a difference in things... I'm with you there, for better or worse. I'm very much that even utilising all of his knowledge and insider information, is absolutely mid pack at best. So sometimes it does feel like a curse... But then on the other hand, I'm 45 and I've spent approx 2/3rds of my professional career working in the bike trade so far, at times earning a decent living being paid to be the person who either knows all about things, or who knows how to fix them, so to speak... So some might consider me very lucky to be quite so sensitive to small changes... The jury's still out for me, as I know it can be both a blessing and a curse... I'll let you know depending on which way my next job takes me within my career I guess!
Posted : 10/01/2026 1:13 am
muggomagic reacted
@mboy Thank you for your insight and time!
Posted : 10/01/2026 8:00 am
Watty reacted
I'd agree with that. A general problem of communication, or at least of how to take the tech detail and turn it into a sellable or memorable message. One of the issues I have with bike marketing/sales is so much of it is about the tech and so little is about how bikes make us feel and to be fair, a good marketer should be trying to turn the engineering into the emotive - and in doing so an engineer somewhere will probably feel 'dumbed down'. It's where small brands have an advantage, the communications are more direct or from the source and the audience is more engaged in the first place.
FWIW I rode a Starling recently, briefly. I wasn't ragging it, the local trails aren't that hard and it was wet out, but I liked it a lot. It felt 'right'. I once had a Commencal Meta 5 that I really didn't like. Too much swingarm flex, felt I was reacting to the bike as much as the trail.
Posted : 10/01/2026 9:44 am
You'll know James, a bike designed purely by committee will have no identity, no real purpose, it'll just be a hotch potch of compromises that mean very little to anyone... Its blandness will nullify any passion and yet more than likely it will be a sales success because it is so inoffensive ..
I know what you mean. Committees can do a very good job though - I expect the big brands like Trek, Cannondale and Specialized are design committees of sorts. With good direction they can do impressive things. It's all in the direction.
Not everything needs to be in a niche to be credible and brands often need a stable sales base that will come from more recognised mainstream formats. The mainstream stuff can support the more niche or experimental parts of the range. Whether that mainstream range is needed probably depends most on the brand size and position.
Posted : 10/01/2026 10:08 am
The quick change battery must be the future?   Especially if manufacturers all use the same batteries!  That would be the dream surely. Battery exchange stations or battery hire for long rides and mtb holidays.   Bike locked safely away and bring the battery indoors to charge up at home or on holiday and keep an eye on etc.
I think Cotic may have started something here.
Yes the battery does look a little bit clunky , but so does the new VW Transporter (...or insert other brands) . But we would get used to it and some of us are wear Hi Viz on the road because its a sensible thing to do!
I would have a top tube bag of some sorts anyway and a dark colour to make it stand out less ,maybe frame wrap or something on it?
I really like the idea and this bike and will now see if they bring out a more xc type version as I maybe a tad overbiked if I bought this one, I love steel frames and will crunch the geometry in abit more detail and maybe go for a test ride as well.
Plus at some point in the future , I do think some hotels etc will ban bikes inside , not understanding that not all bikes are made in China or like scooters.  (Insurance companies will force this to happen?)
 So batteries may need charging in a safe fire proof "box " or cabinet or something so quick removal a good solution .
I do not own an ebike (yet) , but this may temp me much more now and for that huge investment if its more future proof that is a good thing as well.   The Harly Davidson of the mtb world for us oldies for which horse power is not everything anymore.
Posted : 11/01/2026 10:46 am
Posted by: Aggs2
I may be missing something here but what exactly have they started? Plenty of older E-bikes had a cheap looking battery case stuck to the down tube like that and plenty of current bikes have removable batteries. I could well be wrong but it just looks like a cost effective way of getting a (needed) E-bike to market whilst keeping their DNA?
Posted : 11/01/2026 4:08 pm
 aggs
Some of us are not clued up on the latest ebikes and removable batteries etc.
The design makes does sense on a steel frame........
Posted : 11/01/2026 4:24 pm
Not for me but kudos for going with something different.
For me my spindly steel hardtail compliments my emtb because its so different.
Riding each reminds me how good the other is in its respective lane.
Posted : 13/01/2026 2:17 pm
I keep coming back and reading this thread, I think its the non-serviceable Shimano motor that puts me off more than the battery.
Full price E-bikes aren't a cheap hobby and the difference between having a motor rebuilt appears to be £350-400, while replacing a Shimano motor at £800-900 is around double. Still not a deal breaker if you can afford the Cotic but the idea that it can't be fixed is just wrong.
Although by the time it dies you will hopefully be able to swap it out for the Intradrive 🙂
Posted : 14/01/2026 7:18 am
I wonder how many/few they've sold. Considering the number of cotic fans on here (me included!), it's notable that no one seems to have bought one. But perhaps not surprising given the cost.
Posted : 14/01/2026 8:33 am
I wonder if more people would like one but are put off by the cost or can afford one but are put off by the looks?
Posted : 14/01/2026 10:47 am
"no one seems to have bought one" ?
Posted : 14/01/2026 11:00 am
I agree on repairability, but when I was looking at the weekend (not because I need one, just out of interest for when/if my other half's Rise motor dies one day) they were £500-600. Which seems crazy... but then some people have long cage £500 rear derailleurs hanging down behind them... so on balance, perhaps not.
Posted : 14/01/2026 11:27 am
Poorly worded. I meant no one who posts here.
Posted : 14/01/2026 11:31 am
kelvin reacted
Posted by: Mugboo
Motor repairers can only repair so much on 'serviceable' motors like the brose and bosch.
my brand new shimano motor (with a new 2yr warrenty) from madison was £400. Not bad for 3.5yrs uplifts i recon. apparently (accordign to the dealer that sorted mine)  madison/shimano have a sliding scale of cost v age or something. the longer it goes for, hte more discount. i had to return the old one. it wasnt chipped/derestricted.
What i`d like to know (singletrack to do some journalism on) is where the returned motors go? landfill? - refurbishment? etc etc
Posted : 14/01/2026 4:33 pm
kelvin reacted
 StuE
Certainly can't go into landfill in the UK/EU due to weee regulations.
Posted : 14/01/2026 4:50 pm
@VanHalen I've been asking the same ever since Bosch had to replace my Gen 2 motor 4 times in 2 years 🙄Their website looks all " green" and environmentally friendly but when I asked the question they quoted commercial sensitivity to avoid answering 🙄I asked STW they were going to do some digging but not sure if they have ? I don't care for the arms race going on ATM from the likes of Amflow I think reliability is far more important
Posted : 14/01/2026 5:59 pm
the EU's new "Right to Repair" directive, applying from July 2026, extends to bicycles, including e-bikes, aiming to make repairs more accessible and affordable by obligating manufacturers to provide parts and repair info, even outside the legal guarantee, fostering independent repair and reducing e-waste.
Will be interesting to see how this goes.
Posted : 14/01/2026 6:04 pm
It will be interesting indeed to see that!
Posted : 14/01/2026 8:25 pm
The above reply may have appeared a little sarcastic… when in nightime mode I can’t see some stuff - it shows up very light grey on a white background, as do messages!
Is the UK planning on mirroring the EU right to repair directive or will it go the way of wildlife protection?
Posted : 15/01/2026 1:02 pm
Does that apply wholly in the UK, or only for bikes sold or originating in EU?
Posted : 15/01/2026 1:10 pm
I could be wrong on this but I think the reason the Shimano motor isn’t reparable is because Shimano won’t let people use the diagnostic software.
ie the motor itself , bearings etc can be replaced , but say for example that’s what a repair centre does, and when they put it all back together it stops working, they have no way of diagnosing the issue
Of course that could be all trollocks but I’m sure that’s what I found out when researching whether to get a Shimano motor
I also read though that Shimano are quite good with replacement motors (I don’t kid myself that riding an mtb is in any way ‘green’)
Posted : 15/01/2026 1:16 pm
Posted by: oldfart
Does it really matter? The carbon frame the motor is wrapped around certainly isn’t recyclable. The whole notion of mountain bikes or even more so e-bikes being green is a total fallacy in the first place
Posted : 15/01/2026 1:34 pm
Posted by: chrismac
my aluminimum frame is certainly recyclable - and the casing of teh motor is definately re-usable after a motor failure. the electric inside and some parts are probably disposable. but a fair bit should be able to be refurbised.
i`m under no illusion the bike is 'green' - but if we shimano do refurbish rather than just smelting it down and re-casting  then thats a good thing, yes?
in a perfect world the batteries need to be more repairable also. rather than just binning them. mine isnt repairable locally and i`ll need to send it back to Focus i think as, and when, it fails.
Posted : 15/01/2026 2:53 pm
Page 3 / 3
