Bearing suppliers M...
[Closed] Bearing suppliers Manchester pls
As above. I need some new bearings for my Giant Reign by tomorrow night! Any idea where I can pick some up in or around Manchester?
Posted : 13/07/2017 5:07 pm
if you know the size then google bearing shops in Manchester and find the nearest to you - call them to see if they have stock
IME common sizes are pretty easy to get in any shop - Hope Front hub for example - did have to order for the rear iirc
Posted : 13/07/2017 5:09 pm
I've used the bearing mart just below Deansgate by the inner ring road before - not especially cheap, but I assume the quality is decent. You can just walk in and present the bearing numbers. Maestro linkage will set you back 50 quid, if that is what you need.
Also used a place in Stockport in the big mill at Teviot Dale.
Posted : 13/07/2017 5:16 pm
Nice one. Thanks for the tips. Keep em coming..
Posted : 13/07/2017 5:23 pm
 jonk
Simply bearings in leigh have almost every type including the weird hope rear sizes.
Posted : 13/07/2017 5:30 pm
You could drive to BETD, right by M6 junction 16.
Posted : 13/07/2017 5:31 pm
 nbt
BSL have a place in reddish. That's where NWMTB get there bearings
Posted : 13/07/2017 7:16 pm
BSL are now [url= http://www.brammer.co.uk/bearings_seals.htm ]Brammer[/url]
[url= https://eriks.com/en/locations/united-kingdom/eriks-uk-manchester-distribution-and-engineering/ ]Also Eriks in Manchester[/url]
Posted : 13/07/2017 7:44 pm
Simply bearings +1, just off East lancs road
Posted : 13/07/2017 8:13 pm
Motion Industries in Bury if you're in the north. Good range of Fag. Just take your old bearings and they'll match them for you.
Posted : 13/07/2017 8:27 pm
Simply Bearings will be handy for me when the time comes as I work about 100 yards away ๐Ÿ™‚
Posted : 13/07/2017 9:43 pm
Steer clear of Eriks, they'll want your first born as payment.
Proper expensive.
Posted : 13/07/2017 10:02 pm
If your north of Manchester in the Rossendale valley, Darren@Fenwicks in Haslingden is the absolute Oracle of anything to do with bearings.
Posted : 13/07/2017 10:05 pm
Another vote for simply bearings in Leigh
Posted : 14/07/2017 7:08 am
Again Simply bearings in Leigh are great, ship fast and always seem to have a huge range in stock.
They do enduro bearings and the max variations which are designed specifically for suspension.
Posted : 14/07/2017 7:53 pm
