Bearing numpty, hel...
[Closed] Bearing numpty, help required
[#3696738]
Hope ss/trials hus has developed some side to side play.
Checked on the hope web site looking at the exploded view I seem to need
2x 17x30x7 bearings and one 15x28x7 bearing plus a mystery needle roller (no dimensions on the drawing).
Should I expect to need to change the the needle roller thing, I will try to get the parts before stripping the hub?
If i am likely to need to replace it any ideas on sizes or where to get one from?
Other than the bearings do I need to aquire any other parts assuming the pawls etc are OK?
Any help or advice welcomed.
Posted : 20/02/2012 4:08 pm
Apologies for the appalling spelling - really struggle with laptop keyboard.
Posted : 20/02/2012 5:01 pm
i would guess that you need to replace the 3 normal bearings, I would assume the needle roller is for the cassette body.
Posted : 20/02/2012 5:08 pm
If you drop Hope an email i'm sure they would tell you the part number for a bearing kit for the hub, you can then order one through your local bike shop so long as they stock hope stuff. Sonme online stores may have it listed as a kit already so it'd be woth a quick google.
Hope may tell you the bearing type fopr the needle roller bearing if it is not part of a readily available hope after market kit. You could also ask them if it needs replaces with the other bearings in a general hub service or is for the casette section.
Below is the bearing numbers for the specs listed (Hope give you a handy hint with there part numbers). The 2RS is the sealing on the bearing in this case 2x rubber seals (commonly used in MTB application)
17x30x7 = 61903-2RS bearing
15x28x7 = 61902-2RS bearing
If you google the bearing type rather than the spec you may find a better selection.
edited to actually make a little sense.
Posted : 20/02/2012 5:14 pm
Here is a link to that needle bearing if you find you need it
http://www.ukbikestore.co.uk/product/176/hub301/hope-needle-roller-bearing--trialss-cassette.html
Posted : 20/02/2012 5:29 pm
AK bearings seem to be cheap, if you can afford it get the INA bearings
61903-2RS http://www.akbearings.co.uk/search.asp?strKeywords=61903&submit.x=0&submit.y=0
61902-2RS http://www.akbearings.co.uk/search.asp?strKeywords=61902&submit.x=0&submit.y=0
Posted : 20/02/2012 5:30 pm
Many thanks for the replies.
Will get on with it and swap the main bearings out. Can check the innards when fitting them.
Posted : 20/02/2012 6:35 pm
I always find these good on bearings, but they are local to me, and they are mountain bikers
www.onlinebearings.co.uk/6900-2rs-series-thin-section-bearing-pr-16368.html
Posted : 21/02/2012 12:42 am
 mokl
Slight hijack here, but need to replace the rear bearings on the hub of my slightly ageing Bontrager Race Lite Tubeless wheels. I "think" that they are DT 370 hubs and that they need 1x 6000 bearing and 1 x 6900 bearing. I am trying to source some high quality bearings and looked at the links above but quickly became confused! Can anyone clarify what I need, links would be amazing! Cheers
Posted : 21/02/2012 1:05 pm
