I’m aware of some screw together bottom bracket options for the other push fit bottom brackets, but other than the Token Ninja I’m not sure there’s much other choice to replace the bb90?
Wheels Manufacturing do a bb86/92 option but am I missing something on this fitting a bb90 frame? It’s for 24mm axle cranks so that seems fine.
Yours in confusion...
I’ve just posted on my thread from the other day regarding push fit bottom brackets
I’ve gone for the Token Ninja. Looks and feels like a quality piece of kit
They won't. BB86/92 uses bearings in a cup which is then pressed into the frame. With BB90 (trek) the bearings sit directly into the carbon bb shell. I wasn't aware of an alternative for BB90 but as you say, Token appear to do one.
@simondbarnes I wondered if the o/d would be an issue.
@binners token still top of the list then.
