BB30 into PF82
[Closed] BB30 into PF82
[#7867980]
I'm wondering if you can fit a road/ CX bb30 crankset into a bottom bracket she'll that's originally for the Shimano PF82 (I think) system; there must be some kind of adapter out there??
Posted : 04/06/2016 2:14 pm
crank is too narrow. You can do it the other way (std crank in a BB30 frame) but not the other way round.
Posted : 04/06/2016 3:05 pm
Ok, thanks.
Posted : 04/06/2016 3:14 pm
If you ignore the spindle length for a moment, BB shell ID = 41mm, that leaves a bearing that's 5.5mm deep which would require tiny ball bearings that wouldn't last very long. The fact that the spindle is 68mm long fitting into a 68mm wide shell further complicates things. Only 30mm spindle crank that would fit is Rotor or FSA BB386 both use a longer spindle leaving room for external bearings
Posted : 04/06/2016 4:25 pm
