BB30 - Circlip?
[Closed] BB30 - Circlip?
How necessary is it to install the circlips prior to placing the bearings into the frame?
When I removed the previous bearings it didnt look like there was a circlip in there - Cannondale Flash - FSA cranks.
Oh and can you get cheap bearings from elsewhere - esp ceramic ones/
Ta
Posted : 14/11/2011 1:15 pm
You should really have the circlips in the bb shell otherwise the bearings may move in the shell.
I got my last bb30 bearings from www.qwertycycles.co.uk seem to be ok
Posted : 18/11/2011 2:35 pm
In theory, any 61806-2RS bearing should work, and will be a lot cheaper from an industrial bearing supplier than if you buy 'bike-specific' ones. You might have to buy 50 though...
You should be able to feel the circlip inside the BB shell on each side - doesn't sit very proud of the shell surface, IIRC. If they're not there, the bearings won't have anything to stop them being pressed in too far.
Andy
Posted : 18/11/2011 3:06 pm
 LS
Is it an aluminium Flash or a carbon one? The carbon ones don't need circlips.
Posted : 18/11/2011 3:25 pm
a number of industrial bearing suppliers do singles on ebay
Posted : 18/11/2011 3:52 pm
THe frame is a carbon flash - whihc might explain their absence.
Yes I have found suitable industrial bearings supplier, that provide both bearings and circlips.
Any ideas what size the headset bearings are - left headset/fork that is??
thanks
AP
Posted : 18/11/2011 3:57 pm
 LS
B543 2RS I think
Posted : 18/11/2011 4:06 pm
You have got me interested now ATPARRY, what kind of price have you found the bb30 bearings for?
Headset bearing for the Lefty R543DDX1 £23 inc Delivery is the best I have found at this place. Used them a couple of times been quick service so far.
http://qwertycycles.co.uk/collections/bearings
Posted : 18/11/2011 5:02 pm
