Bb width????? 113 o...
[Closed] Bb width????? 113 or 118
[#4554826]
How much difference will fitting a 118mm instead of a 113mm, Isis type bb. Can't find a 113 at a decent price.
Thanks.
Posted : 13/11/2012 8:56 pm
 Andy
2.5mm difference in chainline? Naff all difference i'd say
Posted : 13/11/2012 9:00 pm
Lots in reality.
If it's supposed to run a 113 & you fit a 118, you'll struggle getting the chain to drop onto the inner ring if you're running a triple,rub on the middle more the normal & struggle shifting to the outer.
Posted : 13/11/2012 9:02 pm
What about running single ring on the front then, it has crossed my mind anyway?
Posted : 13/11/2012 9:05 pm
I did this (113 to 118) on a square taper and there was enough adjustment in the front mech to make no difference at all.
Suppose it depends what variation you have to play with.
Posted : 13/11/2012 9:10 pm
