BB Help For Older B...
[Closed] BB Help For Older Bike
[#5062764]
Morning STW,
This is probably a newbie question but I've not had this problem before, my BB has died. It's not a sealed unit, I've had a look and the cages that held the ball bearings were wrecked.
I want to replace it with a sealed BB but I'm not sure what size to go for. The non drive side cup is about 35mm diameter if that helps. Looks to be the older adjustable 3 piece style.
I want replace it a sealed unit, does anyone know if this is possible? I bit of research shows I can replace the bearings but I'd rather just do the whole thing. It's a square taper.
Thanks.
Posted : 13/04/2013 1:36 pm
I would take the bits into your LBS and they will supply you with the correct sealed BB.
Posted : 13/04/2013 2:31 pm
Someone with more knowledge than me should chime in, but I think the only important thing is just the spindle length, so measure that then find the right equivalent in a sealed unit.
To make sure you get the right thing then you could just take all the stuff and your frame into your LBS.
Posted : 13/04/2013 3:39 pm
You need to know the shell width, the thread type (probably English, but could be Italian or French) and the spindle length. Then you should be able track down a sealed unit replacement square taper bb.
Somewhere like [url= http://www.sjscycles.co.uk/bottom-brackets-dept20_pg1/ ]SJS[/url] should have what you need.
Posted : 13/04/2013 4:54 pm
Thanks. New bearings from LBS fixed it enough for now. Cheers.
Posted : 16/04/2013 2:34 pm
